Outside Mirror Woes
Old Mar 11, 2015 | 09:57 AM
Barry713's Avatar
Barry713
3rd Gear
Default Outside Mirror Woes
Hello all, I have a 2004 Z06 with heated and memory mirrors. My passenger side outside mirror had lost quite a bit of range of motion, so I began looking on the forum to see if anyone else had the same issue.
After reading many posts (Thank you for some of the best “how to’s” I have seen), I did not find one that addresses my question so here goes:
I was able to pop the mirror off of the motor just fine and discovered that a piece of plastic (located on center of the motor) that attaches the mirror to the motor has broken off and is attached to the center of the mirror. I was able to remove it, however I am now faced with the task of figuring out how to fix this.
My question is this; Is there anyone that sells just the top of the motor case, or does anyone have a burned out motor they can let go of, and I can hopefully replace the outside cover. If not, what are my options?
Thanks in advance!
Barry
PS) My apologies if this has been addressed, I was unable to locate a post.
Old Mar 11, 2015 | 10:52 AM
dadaroo's Avatar
dadaroo
Contact Marc at VetteNuts.com and see if he can help you with a subassembly.
Old Mar 11, 2015 | 11:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep.. Give Marc a call and he will most likely be your best bet for used repair parts.
Can you post a picture of the broken part? It may help me come up with a recommended repair other than part replacement.
Bill
Old Mar 11, 2015 | 11:28 AM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
^^Thanks guys!^^
We have all the parts in stock to repair your mirror or replace it. Give us a call and we will get you taken care of.
Marc
615-896-6100
Old Mar 11, 2015 | 03:09 PM
Barry713's Avatar
Barry713
3rd Gear
Thank you for all your responses. Here are the pics, and I will call Marc.
Barry
Old Mar 11, 2015 | 03:55 PM
Barry713's Avatar
Barry713
3rd Gear
Barry
Marc is the best!!!
Thank you for the help order placed
Barry
Old Mar 11, 2015 | 04:44 PM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
Barry im glad we could help you out and get your Vette back on the road.
To Outside Mirror Woes
