Stuck in neutral when speed shifting
Old Mar 14, 2015 | 11:21 AM
C5Chad's Avatar
C5Chad
Default Stuck in neutral when speed shifting
Hey guys, I just recently did a cam and heads swap on my 03 base Vette. It has a mgw short throw shifter and a built 6-speed trans all done within the past 8 months. After tuning the new setup it made awesome power and everything was good.
When I got onto the highway and some Backroads though... Doing 2nd gear 40 roll and or 3rd gear 60 roll pulls the car would get stuck and almost like locked in neutral when I would go to speed shift it into the next gear. I would have to pull off the side of the road, shut it off, the clutch pedal I would have to pull back up off the floor and then it would shift through the gears like normal. Driving normally shifts fine, no problems at all. Seems perfect as always. Seeing as how the shifter assembly is almost new as well as tranny, I can't see that being the problem. Is it the fluids maybe? What should I look into and do?
Old Mar 16, 2015 | 07:08 AM
C5Chad's Avatar
C5Chad
Anybody have any ideas?
Old Mar 16, 2015 | 08:35 AM
z-street79's Avatar
z-street79
Did you replace the clutch, slave cylinder pilot bearing, release bearing, and flywheel when you did the transmission? how about the master cylinder?
Old Mar 16, 2015 | 09:35 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
The clutch sticking to the floor sounds like a common slave cylinder problem. Try looking for the "Ranger" method of changing the clutch fluid. Sometimes it helps.
Good luck.
Old Mar 16, 2015 | 12:24 PM
C5Chad's Avatar
C5Chad
I think I'm gonna try changing the clutch fluid out first. See if that does anything. It was perfectly fine before I did the heads/cam swap.
Old Mar 16, 2015 | 12:25 PM
C5Chad's Avatar
C5Chad
Clutch and flywheel was replaced when I did the transmission.
Old Mar 16, 2015 | 12:26 PM
C5Chad's Avatar
C5Chad
Don't remember what all else got replaced when I built the trans. I had a shop do it
Old Mar 16, 2015 | 01:23 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Very common issue (clutch peddle stuck to the floor) after a HP/TQ increase. If you have stock worn GM slave, pressure plare and master cyl stuff, its pretty common.
If it were me, I would install a NEW MASTER Cyl and properly flush and bleed the entire hydraulic system and see if that resolves the issues. Other wise you are in for a LOT bigger repair.
Drain and fill the transmission with the correct ATF Trans fluid and see if that helps smooth out the shifts.
See what you have
Old Aug 18, 2015 | 03:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
See what you have
Any progress on the issues?? Please let us know what you found.
BC
To Stuck in neutral when speed shifting
