Removed both belts and same screeching
Old Mar 17, 2015 | 01:40 PM
Sluggo42's Avatar
Sluggo42
Default Removed both belts and same screeching
Trying to find noise in my 01 zo6
Removed both belts and it still makes a screeching noise. Way worse in the 2k-3k range. Seems to be better when warmed up.
Stumped and afraid something serious is wrong, but car runs fine. Noise sounds like horrid belt screech.
Old Mar 17, 2015 | 01:41 PM
eevette2001's Avatar
eevette2001
From the engine bay? Make the sound with NO belts on it at all???
Old Mar 17, 2015 | 01:54 PM
Sluggo42's Avatar
Sluggo42
Correct, noise with no belts
Old Mar 17, 2015 | 02:03 PM
eevette2001
You have a big problem. Go buy a mechanics stethoscope and start poking around under the hood.
Maybe the AIR pump is on it's way out.
Old Mar 17, 2015 | 02:17 PM
eevette2001
Originally Posted by 8VETTE7
How would that be possible when the pump is belt driven??
Suggest that you look carefully at the harmonic balancer on the end of the crank. Not uncommon for the balancer to have the rubber between the inner and outer hubs fail and the metal outer hub move forward against the rack or backward against the front cover. Easiest to check with the front up on jack stands so you can get under the car....
Looks electric to me
https://www.google.com/search?q=c5+a...Q&ved=0CDwQsAQ
OR
http://www.corvettemods.com/product....FdCmaQodd4sAZw
The harmonic balancer is a known issue, see if it's wobbling.
Old Mar 17, 2015 | 02:19 PM
Sluggo42's Avatar
Sluggo42
No lift available at this moment, I'll have to figure out how to get under the car in the next few days...
The belts are perfectly straight and from the top, it looks correct, but I'll definitely re-visit that.
I wish I knew of a straight shooter mech in SoCal, north of Los Angeles...
Old Mar 17, 2015 | 03:57 PM
4DRUSH's Avatar
4DRUSH
Cam bolts backed out ?
Old Mar 17, 2015 | 04:15 PM
LoneStarFRC's Avatar
LoneStarFRC
How far north? Oxnard good?
A & A Corvette Performance, Ltd.
477-A Lambert Street
Oxnard, CA 93036
Local: (805) 278-4107
Toll Free: (888) VETTEPRO
Old Mar 17, 2015 | 04:23 PM
LoneStarFRC
Yep. AIR pump is NOT "belt driven".
From the symptoms mentioned, I do think the balancer, or maybe even cam bolt(s) (as 4DRUSH mentioned), are the first likely culprit(s).
Old Mar 17, 2015 | 05:40 PM
Sluggo42's Avatar
Sluggo42
Oxnard, CA 93036
Sweeeeet
Old Mar 17, 2015 | 05:42 PM
Sluggo42's Avatar
Sluggo42
Cam bolts?
I think I'll go check out this Vette place mentioned above. Thanks for the link!!!
Old Mar 17, 2015 | 05:45 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Auto trans? Could be a cracked flex plate.
Old Mar 17, 2015 | 05:53 PM
LoneStarFRC
Cam bolts?
A&A is a Corvetteforum vendor and has a very long and excellent reputation. They are also one of the big "go to" vendors for superchargers; sales, installations, etc.
Old Mar 17, 2015 | 05:54 PM
LoneStarFRC
I thought of that too, except he has a Z06.
Old Mar 17, 2015 | 06:10 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Oops, I missed that little tidbit.
Old Mar 17, 2015 | 06:11 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
I think the only downside with going to A&A, is that it'll likely cost you about $7,000 - $8,000 because you'll end up buying a supercharger.
Old Mar 17, 2015 | 06:19 PM
Sluggo42's Avatar
Sluggo42
Haha
Just a supercharger, my wife would kill me
Just talked to josh, and will take it by tomorrow. 15 minutes from my house! How lucky is that?
To Removed both belts and same screeching
Old Mar 17, 2015 | 06:22 PM
LoneStarFRC
No kidding!
In all fairness though, if I were looking for a first-rate shop to get one and have it installed and tuned, it would be VERY high on my list. They really know their chit.
Old Mar 17, 2015 | 10:09 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Another thing it could be is something in the clutch/throw out bearing.
Also, just maybe, the trans is very low on fluid. I've heard manual transmissions scream when really low on fluid.
Old Mar 17, 2015 | 10:51 PM
Sluggo42's Avatar
Sluggo42
It's in the driveway in neutral
