mini relay problems
Old Mar 30, 2015 | 12:44 PM
bigbirdjustin's Avatar
bigbirdjustin
7th Gear
Default mini relay problems
So i just bought my first Corvette. It's a red 99 frc. It is throwing a p0443 code and while i was looking under the hood i saw this
I took the blue wire off and the DIC started saying "reduced engine power" and "service soon". I just dont know where to start looking to get this fixed. Has anyone seen or heard of this before? How do i fix it?
Old Mar 30, 2015 | 12:47 PM
bigbirdjustin
7th Gear
also with the blue wire off when i try to pull codes from the DIC it says "no comm" for every folder.
Old Mar 30, 2015 | 03:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Look in the relay box lid and see what relay that is.
Bill
Old Mar 30, 2015 | 03:55 PM
bigbirdjustin
7th Gear
Bill
it says its fuse #42 Mini Relay - Ignition
Old Mar 30, 2015 | 05:54 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep ,,, Relay 42 is an important one and it looks like the ground wire for the circuit is open and being jumpered by the blue wire to battery ground. Use an ohm meter and check for conuinty
Its used for many circuits!!
Bill
Old Apr 2, 2015 | 08:15 PM
bigbirdjustin
7th Gear
So after going thur some of the wiring i found this next to the starter
The little black wire is just hangin there. Is it supposed to be hooked up to ground g106, the one above the starter?
Old Apr 2, 2015 | 08:27 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is what it is suppose to look like. Yes It is suppose to be hooked to G 106
Old Apr 2, 2015 | 08:29 PM
bigbirdjustin
7th Gear
Thanks Bill, i will get started on it right now and report back later.
To mini relay problems
