Alright guys, I've got a tough one. LS1 corvette, ran out of gas (may be related) one night due to a faulty level sender. Next day it dropped cylinders, I've been able to identify cyls 5, 6, and 8.. possibly 7.
- Pulled the injectors, soaked them, cleaned the rails. Rail pressure is solid, I've got a gauge in the car.
- Verified injector harnesses are sending signal. Fired up, same problem.
- Swapped a known good injector/coil to a known bad cyl, issue didn't move.
- New plugs, new wires, no change. ...
- Spot checked compression, Cyl 2 is ~180psi, Cyl 6 (bad) is ~170psi
I have compression, spark, and fuel... But I can hold my finger on the header primary tube on the dead cylinders while it's running.
LS1 short, LS6 heads, Comp cam, P1SC on 8psi, 60# injectors, TR6 plugs gapped at 35, full non-catted exhaust
I'm lost, any ideas? Would the rear knock sensor failing cause only the back half to malfunction? Would a valvetrain issue have cold compression but not seat the valves while it's running? ECU?
I AGREE,, or a bad valve. Had a Friend with the EXACT same symptoms. Had a bad #7 valve.
Get an Inferred Thermometer and measure the same spot on all eight intake manifold runners right before it attaches to the head while the engine is running. If one or two are a LOT hotter than the rest, look at those valves, springs and or piston lands.
If exhaust gasses enter the intake manifold on one of the rear cylinders, it will MOSTALY effect the REAR cylinders.
So you have 4 dead cylinders? Compression is good on those cylinders looks like from what you posted. Have you checked to see if you have spark on those cylinders? If it was one cylinder I would say a bad coil pack but 4 cylinders all at the same time? even a broken spring like mentioned above would still only be one cylinder. Are you getting any miss fire codes? Or have they tuned out your miss fire
Not true at all. Depending on where the broken spring is it can slow the crank enough to throw the timing off to the other cylinders causing cold holes. Mine was on #6 and the back 2 cylinders on each side were cold
I would not in 100 years thought that a bad valve on ONE cylinder could have made FOUR cylinders loose power but,, it did.
If it would have happened to a cylinder in the front of the intake manifold, it would have had some what less of an effect but, a cylinder at the rear of the intake manifold,, the air flow is different and the exhaust gasses entering through the intake has an effect on more cylinders.
BC
Maybe the sequence of the firing-order had some effect?
Sorry guys, I thought I updated this. Outkast called it... turns out it was a failed spring on cylinder 7, that also bent the pushrod. I'll be swapping in 105 wall Trend rods and double springs... undecided on springs so far. Hoping I didn't damage the valve but I'll get it all back together and check compression before I call this job done.
Since it was an intake spring, air was running back into the manifold and performing witchcraft on a few more cylinders.
When mine broke I used a rubber band around the stem to keep the valve from dropping. I then raised and lowered it in the guide to check for binding and then pulled it up into the seat while spinning it in my fingers to check for a bent head. Good luck with your rebuild, hopefully all is well. What was the brand of spring and mileage?
As far as I can tell it was on stock springs, the previous owner had the heads ported and I see no records of springs when the cam was installed. Mileage on the LS6 heads is unknown but the porting was done 24k miles ago and 65k on the chassis
