I've found a good writeup and it looks pretty damn easy. My question really is regarding the template. I see the reference hole and all that, but I'd heard that the template wasn't all that accurate? Is this true? Is there an adjustment I need to make to it? Also, does that rubber boot stretch enough or do you have to cut it to remove it from the stock MC and install to the tick?
Nope. I was bleeding the slave in order to try to fix my pedal drop issue. Finally start to get pressure in the pedal and fluid poured out of the rubber sleeve on the master line. I pulled the sleeve off and narrowed it down. The fluid was pushing through the braided line about 2" up from the quick connect. No visual indication it was broken, but it leaks
The Tick MC comes with a silicone heat sleeve already on the line.
I was referring to the braided remote clutch bleeder line that (GeneralMotors4Life) was referring to & (brplatz) had chaffing/leak issues with.
I haven't seen one remote clutch bleeder line come with any type of heat/chaffing material with it.
The Tick's braided line does indeed come with a heat proof/non chaffing protective sleeve......but of course I added an extra (Kool-It )heat sleeve over that too.
When you have the Tic Mounted through the fire wall, leave the white plastic M/C reservoir & clamp off until you first slide on the round black GM fire wall boot.
My complaints are not with the remote bleeder. It is with the actual line from the AN fitting on the Master Cylinder to the quick disconnect
Got it all in yesterday, pedal stroke is noticeably shorter now and the way I have it adjusted the pedal grabs a little higher off the floor. It's easier to get in gear from a stop and I can finally bang gears like a proper manual transmission car. Now to address the vibration issue at 3800 RPM. . .
