2002 front blinker issue
Old Apr 30, 2015 | 07:32 PM
CPL's Avatar
CPL
Cruising
Default 2002 front blinker issue
I have a 2002 corvette and the other day both front blinkers went out at the same time. the back two work fine but the front two do not. I have not changed the bulbs because I can't believe that they would both go at the exact same time.... any ideas?
thank you
Old Apr 30, 2015 | 08:00 PM
73Corvette's Avatar
73Corvette
write them down and post them here...it may just be a bulb, but this will be good practice anyway.
Old Apr 30, 2015 | 08:06 PM
Darrell98's Avatar
Darrell98
I have a 1998. The right front bulb goes out on a regular basis, about every six months. I carry a spare.
Old May 1, 2015 | 10:34 AM
dadaroo's Avatar
dadaroo
thank you
Do the DRLs work? If they do it is not the bulbs.
Old May 1, 2015 | 10:37 AM
dadaroo's Avatar
dadaroo
You apparently have a heat related issue where the DRL has melted a hole in the top of the housing or it is cracked. You get water in and no more bulb. Can also corrode the connector. Very common issue.
Old May 1, 2015 | 10:59 AM
CPL's Avatar
CPL
Cruising
Yes, both rear signals work but blink quickly and both fronts do not blink
Old May 1, 2015 | 12:43 PM
lionelhutz's Avatar
lionelhutz
It's either the multifunction switch, wiring or the bulbs. I'd check the bulbs first.
If you have holes in the housings, which is quite common, then washing it with the bulbs hot could blow both bulbs at the same time.
The last common point between both sides is the multifunction switch. Once past that, each have their own wires and grounds.
It can't be the hazard switch, even though someone will probably tell you it is.
Old May 1, 2015 | 01:12 PM
73Corvette's Avatar
73Corvette
Multifunction switch or wiring throw a code? Or the grounds?
Old May 1, 2015 | 06:00 PM
lionelhutz's Avatar
lionelhutz
If you are asking if any of that will throw a code, the answer is No.
Old May 1, 2015 | 09:01 PM
73Corvette's Avatar
73Corvette
That was the question... thank you! Still trying to learn from you smart guys
Old May 2, 2015 | 08:27 AM
dadaroo's Avatar
dadaroo
Thanks, but I was asking about the DRLs. They are the daylight driving lights (in the front) that are on when the headlights are not being used. They use the same bulb filament as the turn signals. If they work then the bulbs are good.
Old May 3, 2015 | 06:51 AM
CPL's Avatar
CPL
Cruising
yes the DRL work and the Hazards work correctly...
Old May 3, 2015 | 07:16 AM
dadaroo's Avatar
dadaroo
That means the bulbs are good. Would seem your MF switch is bad. When you use the Hazards the fronts are not powered thru the MF switch like they normally are.
The Blue wires go to the Front and the Green and Yellow go to the rear.
Old May 3, 2015 | 07:20 AM
CPL's Avatar
CPL
Cruising
This is very helpful, thank you!!! This may be a dumb question but, where is the MF switch located?
Old May 3, 2015 | 07:22 AM
dadaroo's Avatar
dadaroo
This link should help if you want to DIY.
https://www.corvetteforum.com/forums...-a-how-to.html
Old May 3, 2015 | 07:27 AM
CPL's Avatar
CPL
Cruising
Thank you!
Old May 3, 2015 | 07:34 AM
dadaroo's Avatar
dadaroo
If you run into any issues let me know.
Removing the knee bolster is not hard but there are two metal clips at the far left that may be hard to release. When I removed mine one released and the other did not but slipped off the bolster and remained in the dash. Not an issue, it can be replaced back on the bolster and you would never know.
If you want some pictures just PM me with your email.
To 2002 front blinker issue
