1st-2nd gear grind
Thoughts? Clutch fluid possibly? Hopefully not a synchro.
Car is an Ls1 with t56 mn6 transmission.
There are 2 ways to do a "true" bleed if the Ranger method does not help. One is the factory directed FSM method and the other is to remove the intake manifold for access.
I have a link that covers both at home if you need it.
http://www.corvetteactioncenter.com/...ml#post1163395
Though when you shift at high rpms does it feel like theres a wall going into 2nd gear? Does it do it in any other gear, Like 2nd to 3rd at high rpms? I had a similar issue with 1st to 2nd and 2nd to 3rd at high rpms it feels like a wall when shifting and it sometimes would grind. I ended up installing a tick master cylinder and it cleared up my 1st to 2nd high rpm problems but 2nd to 3rd remained with hesistation getting into gear but wont grind whatsoever.
It could also be your clutch Master cylinder crapping out the easiest way to find out is to find a very lonely empty area and leveled surface put the car in 1st gear with the car on with the clutch pedal pressed all the way to the floor hold it and rev the engine to redline and take note if the car moves forward or lurches forward the clutch isnt fully disengaging. So your master cylinder would be going bad.
Order some AMSOIL Torque Drive ATF.
It could possibly eliminate the grinding all together. It did in my 98 MN6 Coupe.
The old fluid that came out looked like dark red metal flake paint and that was at 50,000 miles. Could be a very inexpensive FIX.. Order 4 Qtrs.. You will use 3.75 of the four qtrs. on a wet refill..
BC
