Automatic dies when put in gear
When I test drove the car, it had been in storage for a while the guy said. I don't know how long. It was traded to a diesel truck dealer so they knew little about the car. The battery was dead, so they bought a new one that day. The car started up right away. It sounded amazing. I put the car in reverse, and it dies. So it does this a couple more times, then after it "warms up" I was able to back. Out and drive it without issue. I was worried, but other than that the car runs perfectly. So I negotiated the price down $1,300 below the lowest kbb price. The next day I drove it fine after letting it warm up for a few minutes. Then today I back it out of the garage, and it dies as I go from reverse to drive. I continue to drive it to work. I go to leave for lunch, and it dies as I put it in drive. It doesn't have a consistent idle. Sometimes it idles at 900 rpm, and sometimes at about 600 rpm. Also the oil psi stays between 50-65, which seems high. My guess is the car needs a tune, but I have no experience with vettes, and little experience with "race cars". I know this is long, but if you need more info ask. I just bought the recommended oil and filter to change since I don't know what this diesel place put in it. Any help will be appreciated.
Chris
You have one or several common issues that are easy to check:
1- Examine the PCV rubber fitting on the passengers side of the intake manifold just aft of the throttle body. Make sure that it isn't deteriorated and causing a severe vacuum leak
There are several other mechanical fittings on the complete PCV Pluming that need to be checked for a vacuum leak. Here is your PCV SYSTEM in schematic format:
2- The air ducting between the Throttle Body and the MAF "MUST" be air tight and leak free. Make sure that the fittings between the MAF and TB are properly connected and sealed.
3- Throttle Body Blade and MAF Sense Wires Dirty. Use MAF Spray cleaned and spray the MAF sense wires clean. Clean the Throttle blade while you have the air ducting removed.
Read and post any DTCs that you have. Here's how. If you have a TON of DTCs, clear ALL of them and see what comes back. Report those findings:
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine. NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Fluid here, and a drip under the car around this location.
Inside the Throttle body there was some fluid. I looked inside, and there was signs of fluid inside the intake. Appeared to be oil.
This nipple had no hose or cap. I don't know if it is supposed to be.
The uncapped fitting under the TB is a coolant passage inside the TB that people remove. Its will have ZERO effect on your issue. If its uncapped, it has been bypassed and is no longered used.
The fitting that you show in the pic whr you say theres fluid on the head area, is a steem crossover pipe. Yes, then can leak coolant. Check the tightness of the fastener and if its tight, the gasket under the titting could be bad.
The oil in the intake is from the PCV system.. Install a catch can to help control it.
How many miles on the stock O2 sensors?
Have you ever cleaned the MAF?
BC
Do u have access to a scanner that's capable of reading ur 02 sensors? Couldn't hurt to double check so u can cross that off the list... I say this Cuz I've seen 02 sensors be bad but still giving a goofy reading as to not throw any codes.
That's my WAG.
That's my WAG.
