New bcm? Yikes!
40 BCM B2721 H C
about 20 other history codes.
Do I really need a BCM, quoted at $1550.00 installed, or is there some other things I should do first?
Your first mistake was taking it to a Stealership. They want to STEAL your money because you are ignorant of codes and their meanings.
Here is how to pull your own codes:
OR
http://www.c5forum.com/ayc/dtcdic.php
Get to the car and pull the codes yourself and then POST ALL of them here including the H or C or HC that follows each 5 character code.
EXCELLANT chance that most if not all the codes are because of the dead battery.
Headlight problems are COMMON in the C5 and I have NEVER EVER heard of needing a new BCM to correct those.
10 PCM p1631 H
40 BCM B0432 H
B0502 H
B0503 H
B0508 H
B2482 H
B2483 H
B2528 H
B2721 H C
AO -LDCM
B2282 H
B2286 H
B2284 H
U1064 H
A1-RDCM
B2283 H
B2287 H
B2285 H
U1064 H
A6-SCM
B0851 H
B0856 H
yeash.
Your getting excellent guidance. DO NOT let then talk you into BCM replacement. As far as I can see,, your BCM is fine.
Provide the info 8VETTE7 requested and I'm positive that you will get the answer you need.
Bill
40 BCM B2721 H C
I did not hear any grinding when the lights quit but I was driving, however the bulbs were intermittent when the lights were up before they quit coming up all together.
My twilight function is off.
everything else seems to be working well except an intermittent security light that stays on while driving from time to time.
the Headlight issue.
I was driving in early morning with lights on, the bulbs turned off but the headlight stayed up. I tuned them off they closed and when I turned them back on they flipped up and were lit. this repeated a couple of times but the second and third I had to repeatedly turn the lights on and off so that the bulbs were lit when they flipped up. then the they just wouldn't flip up at all. now when I turn them on there is no noise, and the lights do not flip up, all other indicators and running lights act as if the headlamps are on.
1. - IF,,, you get a new KEY,, and you want a new SENSOR to read the resistor pellet on the key,,,,, YOU MUST order a new KEY CYLINDER. The sensor is part of the key cylinder.
When you receive the new cylinder, take the new cylinder and a NEW DEALER CUT KEY (Yes they can cut you a new key from your VIN Info) to the Lock Smith. The locksmith will re-pin the new cylinder to fit your OLD / New OEM key.
Its a little time consuming and expensive but,, one key will unlock the car, the ignition and be the correct resistance and the sensor will work.
2. - HEADLIGHTS. Your Steering Column "MULTIFUNCTION SWITCH" controls the Headlights and the Door Opening /Closing signal to the door motors. I my opinion,, It sounds like the Multifunction Switch is going bad. Its a pretty common problem and they do go bad.
Here is a Post that details repairing the Multifunction switch yourself:
- C5 Multifunction Switch repair - http://forums.corvetteforum.com/c5-t...f-replace.html
Before I started replacing components I went through everything one last time. Grounds and fuses good, no other codes, no noise when headlight switch turned on. then I noticed if I pulled the mf switch forward the bulbs would light but the buckets would still be in the down position. I also had read a suggestion by dadaroo on another thread to try the twilight sentinel mode on - low and behold the lights flipped up and came on! This leads me to believe that the mf switch is bad and the signal to flip up and turn on is not getting through. I think this means my hcm is ok and definitely the bcm is ok. Unless you guys think otherwise I will swap out the mf switch for a new one.
How to remove it link:
http://forums.corvetteforum.com/c5-t...-a-how-to.html
Repair link:
wow, great links! Thanks. I will check into how much a new one runs, it may be worth it to get a new one if it means I won't have to take the column apart again anytime soon. Thanks again for all your help I would be stuck with a new bcm and lights that didn't work if it wasn't for you. I also have learned a lot about my car by browsing this forum, it is awesome.
