Air Pump Issue
Old Jul 9, 2015 | 05:25 PM
99torchredcoupe's Avatar
99torchredcoupe
3rd Gear
Default Air Pump Issue
I've replaced the air pump twice in the last 4 years on my '99, and believe it may need replaced again as the check engine light came on again. Seems unusual since I've put less than 1,500 miles on the car in that time. I have been told that it is not a critical component and that it only runs on initial startup? Car still runs fine even with the check engine light on. Could it be something else causing the problem like a sticking air valve, bad relay etc? Car has a Blackwing air filter. Can the air pump be disconnected and bypassed altogether? If so how do you clear the codes? The car is emission exempt so passing an emission test is not an issue.
Old Jul 9, 2015 | 06:05 PM
chris308's Avatar
chris308
A tuner disabled mine when I had headers put on and tuned.
Old Jul 9, 2015 | 09:12 PM
grantv's Avatar
grantv
Starting from the front end...
Are you getting vacuum to the air pump?
Is the fresh air tube from the Blackwing hooked up and no blockages?
The pump itself, I highly doubt you would have 2 break in such a short time without something causing the failure.
Post pump, unless there is a blockage in a line, or both of the valves are sticking I can't see a problem there.
Are you capable of doing some checks?
Old Jul 10, 2015 | 07:28 AM
dadaroo's Avatar
dadaroo
You are just wandering in the dark if you don't know the codes.
Old Jul 10, 2015 | 07:31 AM
99torchredcoupe
3rd Gear
Probably could do some basic checks, what dp you suggest??
Old Jul 10, 2015 | 07:57 AM
runner140*'s Avatar
runner140*
Suggested several times to pull the codes.
Old Jul 10, 2015 | 08:07 AM
dadaroo's Avatar
dadaroo
Apparently he still just wants to wander in the dark.
Old Jul 10, 2015 | 08:48 AM
vettenuts's Avatar
vettenuts
Codes will tell you if it's the pump or check valve. Typically the check valve behind the heads that is for the passenger side it the problematic one. But as others have said, pull the codes to aid in diagnosis of the problem.
Old Jul 10, 2015 | 10:17 AM
grantv's Avatar
grantv
This is where to start. Scroll up to where it shows pulling codes.
As far as removing the AIR system altogether, I did, many do. It's only a cold start emission item. After about a minute it's off until your next cold start. A tuner can prevent the codes from appearing. If your local laws require it in place however...
Pull all codes, list them here.
Old Jul 10, 2015 | 05:08 PM
99torchredcoupe
3rd Gear
Thanks, that pretty much answers my question about whether the AIR pump is really needed. I'll get the codes pulled (my friend is a Chevy mechanic) and if it is the pump I'll do as you suggest. Problem with the pump itself is that the replacement is made in Mexico and quality is a concern Plus it is a $300-350 repair at the local Chevy dealer. Rather spend my money on other mods.
To Air Pump Issue
