02 ebcm replacement
Old Jul 14, 2015 | 01:34 PM
gbkent's Avatar
gbkent
1st Gear
Default 02 ebcm replacement
I'm new to the forum and my first Corvette. My in dash display said service traction control service abs, I got a diagnosis that the problem was my EBCM. I bought a rebuilt on line, saw it was six small screws and two electrical connectors and said I can do this. I unplugged the connectors, removed the six screws it won't budge. I tried tapping it with a small rubber hammer nothing moved. I don't want to cause any problems by forcing any thing or do I need a bigger hammer? thanks for any help you can give me. George (gbkent)
Old Jul 14, 2015 | 04:04 PM
msgvert's Avatar
msgvert
As you can see I've got a thread on EBCM also - I started at the top with a thin bladed flat screwdriver and gently pried using a twisting motion. It was not too hard to break it away from the other module. I've read elsewhere to be careful with this step and not damage the seal.
Old Jul 18, 2015 | 01:49 PM
TXGS507's Avatar
TXGS507
I too am in the middle of removing my BS module.... I am attempting to remove the module ONLY not the entire unit.... I removed (4) hex head screws.... You said (6)...?? I have looked everywhere for the other two? Cannot locate them... Mine is an 01.... I am going to attempt to gently pry the unit on starting w a butter knife.... wish me luck...
Old Jul 18, 2015 | 02:35 PM
TXGS507's Avatar
TXGS507
found the other two screws..... there is indeed 6 on the 01 model.. lol
Old Jul 19, 2015 | 12:22 PM
OUTAKTRL's Avatar
OUTAKTRL
Use a small flathead screwdriver or a small taping knife. Run it along the top edge of the ebcm and once u break the seal it comes off easily. Just be careful not to ruin the seal for when u reinstall.
To 02 ebcm replacement
