TCS C1241 Gremlin
My steering rack was leaking and replaced last month, I hoped this would fix the problem but sadly the stiffness in the new rack just makes turning at low speeds even MORE difficult.
I have checked the wiring between the EBCM and the rack, there are no shorts to ground or power, the continuity through the harness is good. The resistance at the rack is 2.0 ohms. The resistance at the EBCM is infinite. But! There is NO current at the connector with the engine running. This leads me to believe that the EBCM is at fault.
However... when I took it to Zip Corvette and they hooked up their Tech tool my steering wheel position sensor showed 0 at all times in all positions. This makes me think that something *else* may be going on here.
I don't want to set to work on the EBCM if it is not the issue.
I have no other trouble codes and everything else seems to be working properly.
Any help, suggestions or insight would be greatly appreciated.
https://www.corvetteforum.com/forums...cuit-help.html
https://www.corvetteforum.com/forums...ode-c1241.html
It seemed from my reading that whichever system is at fault there should be some other error codes as well.
It is my understanding that the lone C1241 strongly points to a simple wiring issue, which apparently does not exist.
Puzzled!
Have you checked to make sure the sensor is not shorted to the housing? I know the coil resistance is correct from your measurement.
I have attached the 2003 info for you. It says at low speed the current is a negative 2 amps so not sure how you measured current.
Was this code there before you changed the rack?
Here is the info:
https://www.dropbox.com/sh/6yikijl1w...2LlgjOcRa?dl=0
Let me know if you can think of anything else I can do.
Mr. Sam
I've managed to find a supplier for a new EBCM that will let me return if not needed, and as the SWPS feeds into the EBCM as well I think it is probably worth the time and effort to see if it is the culprit.
Thank you for all the info. I think maybe it's time I should invest in a FSM too.
