Cat delete
Old Jul 22, 2015 | 11:37 AM
Lucas456's Avatar
Lucas456
Default Cat delete
So I want to remove my catalytic converter and run straight pipe.
I already put a borla stinger exhaust on. All the cat delete pipes I've seen for sale are for a c5 with headers. Does anyone know of a cat delete system for non headers? TIA
Old Jul 22, 2015 | 12:06 PM
grantv's Avatar
grantv
If legal to remove where you live, any decent muffler shop can make you new front half of your mid-pipe for a reasonable amount. Just a thought...
Old Jul 22, 2015 | 02:21 PM
Nate@VanBortelChevy's Avatar
Nate@VanBortelChevy
Platinum Supporting Dealership
Buy a second hand mid-pipe for an early C5 (without pup-cats), have shop remove cats and weld in pipe.
Old Jul 22, 2015 | 02:29 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its ILLEAGLE to remove the cats in ALL 50 States (Federal Emissions Law) so, that theory is out.
Only out is if the car is not to be driven on legal roads. Track, private properly etc.
That's not to say, people are law abiding and follow the law/rules.
Old Jul 22, 2015 | 02:47 PM
Lucas456's Avatar
Lucas456
Oh ok and thanks for the info guys. I live in texas. So any other tips to make it louder? I've already got the borla as I said before.
Old Jul 22, 2015 | 02:58 PM
grantv's Avatar
grantv
-Louder mufflers
-Maybe aftermarket cats a tiny bit louder?
-Headers
-Cam
-Higher compression
-Bypass
Old Jul 23, 2015 | 12:34 AM
Not4spd's Avatar
Not4spd
I feel your pain as living in an emissions county and trying to find a shop to remove the cats is like searching for a needle in a haystack. They don't want to risk it. It's a damn shame a vendor doesn't make a bolt in kit. When I had my fox body it didn't seem to be an issue. With my Vette not happening.
An option would be to add cutouts, but even then shops won't want to weld them in before the cats. Your best option is to find an aftermarket axle back that suits your needs.
Old Jul 23, 2015 | 08:02 PM
NemesisC5's Avatar
NemesisC5
Here you go $159.99
http://www.breathlessracing.com/inde...&productId=879
Old Jul 23, 2015 | 08:34 PM
Lucas456's Avatar
Lucas456
Awesome thanks, will this connect to a borla exhaust?
Old Jul 23, 2015 | 08:45 PM
NemesisC5's Avatar
NemesisC5
Cut out cat portion of factory H-Pipe and install in its place. C5's actually have great flowing oem manifolds but factory cats are very restrictive. I had this setup many years ago and gains were noteworthy. Borla cat back will still connect with factory H-Pipe, you'll definitely hear your Borlas a lot more without cats.
Old Jul 23, 2015 | 08:47 PM
Lucas456's Avatar
Lucas456
Ok thanks I will look into that and most likely buy, however gotta wait till the 1st I had an unexpected financial situation.
Old Jul 25, 2015 | 03:18 PM
Corvette#2's Avatar
Corvette#2
Is there anyway to pass emissions without cats or is this usually only done in rural areas without testing ?
Old Jul 25, 2015 | 03:26 PM
Lucas456's Avatar
Lucas456
Crap that's a good question that I do not know the answer too.
Old Jul 25, 2015 | 09:19 PM
lionelhutz's Avatar
lionelhutz
It depends on the test being performed. Passing an ODBII is no problem.
To Cat delete
