Drivers side seat issue
Old Aug 10, 2015 | 07:41 AM
dadaroo's Avatar
dadaroo
OK, I re-read your post so I guess you did access the info. I can explain how to determine what connector view is for what.
I have looked at both connectors (301 and 303) and they do not match what I sent you from the FSM. Some seem correct. We are going to have to first get the 301 and 303 connectors correct for the dash side. Then get the seat side correct.
I will work up what to do and to check they are correct. We need to do this on the phone instead of doing it here to make it easier.
Old Aug 11, 2015 | 12:45 AM
Yellow '01's Avatar
Yellow '01
Yes, I did get them open and I agree that they are probably the correct ones. Tell me what you think. It also looks like I'm missing a green and white wire.... I will give you a call. What time is best for you? Also, do you agree the switch is toast? If you have leads on a good one that would be great. I'll make a thread for one.
Y '01
