Clutch problem?
Old Aug 2, 2015 | 10:06 PM
Dcollins3208's Avatar
Dcollins3208
Default Clutch problem?
This is in regards to my pop's zo6. He has a RPS Twin Carbon Clutch. Recently, he's been having a few problems that we believe to be clutch related, just looking for opinions before we tear it down. The clutch pedal sometimes sticks to the floor and it won't return. When coming to a stop and down shifting, it makes a loud clack when coming to stop. When in first gear, with the clutch all the way in, the car starts to move. When sitting still, he can't put car in reverse, has to kill motor and put it in reverse and then start it. He said he can shift better without the clutch than with. Is there an adjustment possibly?
Old Aug 2, 2015 | 10:24 PM
StingrayRebel's Avatar
StingrayRebel
has it always acted this way since the install?... it sounds to me like the clutch might have worn down a tad bit and the slave will not engage the pressure plate far enough to release it from the discs, that would explain it creeping forward while in gear even with the clutch pedal depressed and making it difficult to shift into reverse... I am not familiar with how the rps clutches are designed but my act twin has shims on the pressure plate studs that can be used for adjustment as the discs wear down so that could be a possible fix or you might even look into a tick master cylinder
Old Aug 2, 2015 | 10:39 PM
Dcollins3208
He bought the car with the clutch already installed, he's had the car since February and it just started acting up about a week ago. Thanks for the info
Old Aug 3, 2015 | 01:27 PM
TwinTurboZ51's Avatar
TwinTurboZ51
I had same issues exactly. My master cylinder wasnt working correctly. It would not fully disengage the clutch, hence the car moving with clutch all the way down. The pedal stuck to the floor frequently too until I pulled the pedal up with my toe. I started to have these issues after I had a twin-disc clutch installed. I installed a Tick master and all those issues went away.
Replace the master. It is a pretty easy job and no tear down of the drivetrain needed. I would bet that this is your issue.
Old Aug 3, 2015 | 01:41 PM
Dcollins3208
You just saved us a ton of work, we literally had the car jacked up and on Jack stands and we were about to drop the drivetrain. Thanks!
Old Aug 3, 2015 | 02:16 PM
LoneStarFRC's Avatar
LoneStarFRC
I agree with TTZ51's advice however there is ONE proviso; the pedal pressure WILL be greater than before. I've become accustomed to mine over the years, but this (pedal pressure increase) is something of a subjective thing, i.e. what is not objectionable to ME, may be to someone else.
Just an FYI to prepare your dad for the increase in pedal pressure. Personally, I would say it was about a 25 to 30% (~) increase. Now that I've become so accustomed to it, I don't even notice it any longer. On the BIG plus side, NO pedal-sticking-to-the-floor syndrome whatsoever.
HTH
Btw, yes I also have an aftermarket twin-disc clutch, but it's a McLeod RST however.
Old Aug 3, 2015 | 02:25 PM
StingrayRebel
tick offers a stock bore master that won't increase pedal pressure from what it already is
Old Aug 3, 2015 | 03:09 PM
Socko's Avatar
Socko
there is a 13/16 and 7/8" tilton, which is what you want if you want something good. The 13/16 only moves a tiny bit more fluid than stock though, and its slightly more pressure. Tick sells the 7/8" only i thought?
The 7/8" is super noticeable at first but you get used to it in a couple weeks. I feel like its easier to control then stock now that I am used to it. It is heavy but its not unmanageable for a normal sized adult male.
Old Aug 3, 2015 | 03:56 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The very first thing that I would try is a good clutch system bleed. If there is any air at all in the system, it will do the same thing. If you are POSITIVE that bleeding will not correct the issue, YES,,, Replace the MASTER CYL!
Once you do that, MAKE SURE its properly bleed.
IF, you go the TICK Master Cyl replacement route, You will have to learn how to properly adjust the clutch peddle adjustment rod.
Improper adjustment and you risk having the same issues your having now. Too much rod and you will have constant pressure on the pressure plate springs and clutch slippage under power.
If you have excessive peddle rod length you also risk over compression of the pressure plate springs and pressure plate spring damage.
See what a good bleed does for you. Do you have a remote bleeder??
Bill
Old Aug 3, 2015 | 06:50 PM
Dcollins3208
Bill
Thanks Bill, he does have a remote bleeder. I will bleed it when I'm able to go his way or will see if he can do it and I'll report back the outcome
Old Aug 8, 2015 | 04:43 PM
Dcollins3208
Just wanted to thank everyone for your help. We bled it and it didn't help, so we put in a new clutch master cylinder and all is well now. Again, huge thanks to you guys because we would have dropped the entire drivetrain thinking it was the clutch
Old Aug 9, 2015 | 10:26 AM
CTD's Avatar
CTD
Having owned a RPS street lite twin carbon, it will not full release with stock hydraulics. My fix was a McLeod MC, it is a slightly larger bore than the stock MC so only a slight increase in pedal which is already brutal with the RPS clutch.
I fought the release issue, they claimed it would work with stock hyd's......it will not. I tried shimming it, had it in & out several times, sent it back to them twice. In the end the pedal pressure was to much for my style.....& the attitude of the company owner
To Clutch problem?
