SDM u1000 and no other code?
No fuel pressure, engine turns over, no start...
I check my codes and find u1000 but no code to tell me which module is in a huff and won't communicate with the Mother Module. I reset the code but it pops right back on.
I pop the hood and check the fuse for the fuel pump. It's fine so I swap my fuel pump Mini Relay with the spare that I keep in the "spare relay" holder.
Nothing. Still no fuel pressure. I disconnect the battery for 30 minutes. The speedometer needle does it's proper full sweep and return but I still have the SDM u1000 code.
I did get caught in a rain storm a few weeks ago and was forced to drive for an hour in very rainy conditions. So I'm thinking the wheel well compartment got flooded and I'll need to get inside of there to look at the harness.
Any other suggestions?
It is an SDM code.
When you got back from your drive in the rain did you check to see if the passenger foot well was wet? Have you pulled the toe kick in the passenger foot well and checked to see if there are any white oxidation stains on the BCM box?? ( Large aluminum container to the left of the fuse box)
I hate to be a bother but I need to drive 2+ hours back to my friends house to work on the car. So is there any other possibilites for this problem?
Here is a thread that talks specificaloy about the "rubber udders" that get clogged and how to clean them:
http://forums.corvetteforum.com/c5-t...ak-checks.html
Suggest you check the passenger foot well and see if there are any white oxidation stains on the case of the BCM. You can also examine the star connectors. Here is info on those:
Post back what you find.
My electronic service manual seems to be a waste of time and money. It doesn't tell me much that actually helps and constantly refers to the use of a Tech 2 scanner. Not much use to me without one of those...
Sigh...
SDM - Sensing and Diagnostic Module - It controls when the airbags are fired, and constantly runs diagnostic checks to be sure the system is working OK. It contains a capaciter that stores enough electricity to fire the bags even if the battery fails in a crash. It also serves as a "black box" capturing and permanently storing the last 5 seconds of vehicle data prior to the crash. Located inside the center area of the dashboard under the HVAC controller
From that it is clear that a U1000 associated with the SDM is not the cause of the no start or the lack of fuel pressure.
If so,, you have a serial data buss corrupted data issue most likely caused by power interruption of the LDCM, RDCM or the SCM....
BC
I tried a net search for the u1000 before I got on here. All of the results that I got back had a other codes to indicate which module wasn't communicating.
I had the pleasure of driving through a very serious storm on the way back. Ya' just gotta love this man-caused global warming that has ended rain and snow...
People pulling off of the road, driving with their emergency flashers in operation, the wind blowing semi trucks into my lane...
Some poor owner of a C5 got caught out in the storm running for home. Didn't make it. Just a little into North Tucson the wind threw him off the road. The car wasn't really smashed so I think that he was OK.
My sympathies go out to him!
I checked the BCM, behind it, and everything around it. No obvious signs of water leaks.
I pulled the ignition switch assembly and test the circuit for the key resistance. No continuity. I check both wires for continuity to the contacts. They are good. I try with my spare key. No good Joe.
So I clean the contacts and find that one side is sticking at a point where there is no contact with the key.
I fix the problem. Now it is raining like crazy.
Damn this Man Caused Global Warming that will cause our kids to never see rain, nor rainbows, nor snow!
I think that I'll just relax in the house for a while...
Then I'll go out and install the ignition switch and check the star connectors.
