0442 code
Old Aug 11, 2015 | 08:46 PM
lucky99's Avatar
lucky99
Default 0442 code
Any ideas how to track down a 0442 evap leak on 2002 coupe
Old Aug 12, 2015 | 06:32 AM
mhanley's Avatar
mhanley
Take it a shop or dealer that can "smoke" the system to find the leak. Just had it done at a dealer for $95 just for smoking. R & R of parts is extra. Mine turned out to be leaking gas cap.
Mike
Old Aug 12, 2015 | 07:35 AM
dadaroo's Avatar
dadaroo
Check the gas cap since it causes this code in a lot of cases. If that is not the problem I can post the diagnostics for you.
Mr.Sam
Old Aug 13, 2015 | 08:02 PM
Mr. Jean's Avatar
Mr. Jean
How do you check the cap? Where do you get a replacement, if needed?
Thanks for any assistance, as our engine light keeps coming on and off, but no codes. Seems to happen soon after getting gas, so the cap is suspect.
Old Aug 15, 2015 | 07:46 PM
frsr06's Avatar
frsr06
Gas cap is about $16 - you can get one at Cultrag - one of our CF vendors or go to your local parts store.
Old Aug 15, 2015 | 08:34 PM
Mr. Jean's Avatar
Mr. Jean
Thanks, just called locally and found one for 11.99 heading over in the morning. Thanks.
Old Aug 15, 2015 | 10:03 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Gearchatter has the best site for diagnostics of codes in plain English--about 1/2 way down in the boxes it describes simple things to look for and the most often causes---
A small vacuum leak is often related to an aftermarket gas cap--they never seal correctly as most are universal fit--get the correct cap from the dealer
http://www.gearchatter.com/viewtopic10457.php
Old Aug 15, 2015 | 11:22 PM
Mr. Jean's Avatar
Mr. Jean
thanks for the information and link. I'll check it out.
Right now I'm getting the P0171 and P0174 codes.
To 0442 code
