charging question
Old Aug 15, 2015 | 05:08 PM
slider_buck's Avatar
slider_buck
Default charging question
i just bought my first ever vette the other day. absolutely loving it so far. should the alternator drop off to about 12.8-13 when sitting in stop and go traffic after awhile? once i get back up to cruising speeds the voltage comes right back up to 14-14.5
Old Aug 15, 2015 | 05:36 PM
73Corvette's Avatar
73Corvette
The fans may be kicking on and pulling some voltage... haven't paid much attention to mine but, that sounds like it would be a normal thing...there are probably many other factors that would make voltage fluctuate some...
Old Aug 15, 2015 | 05:58 PM
slider_buck
hopefully thats all it is. i never notice it doing anything different while on the road. it just happens once im in stop and go traffic for awhile
Old Aug 15, 2015 | 08:21 PM
slider_buck
its all stock as far as i know. its a 2002 6 speed hard top with the z51 package. has 80000 miles. i just bought it from a dealership. if it was underdrive pulleys id think it would drop off just as soon as my rpms drop. it doesnt do it instantly. just after ive been in traffic for a few.
Old Aug 15, 2015 | 10:09 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Yes quite normal for the voltage to drop at idle---Especially when the A/C s on which means BOTH electric fans are ON and may use as much as 50 AMPS---
The only time you may have an issue is if the car won't start--meaning you either have a battery going south or the alternator is not charging enough----
PS these cars with all their electronics are highly voltage sensitive--meaning that if the voltage stays low for a long time you'll begin to notice weird things happening to most all the electric components such as windows--door locks--cruise control column lock--alarm etc---
Old Aug 15, 2015 | 11:06 PM
slider_buck
thats what i was just mainly wondering. if its normal for these cars to drop like that when idling around for awhile. never had any other car do that but ive never had a Vette either
Old Aug 16, 2015 | 08:08 AM
dadaroo's Avatar
dadaroo
Probably not an issue. Do this, start the car when it is cold and do not turn on the AC. Tell us what the voltage is at idle.
Old Aug 16, 2015 | 05:42 PM
slider_buck
its always above 14 when its cold. it only drops like this when im in stop and go traffic
Old Aug 17, 2015 | 02:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
How are you reading the VOLTAGE???
The dash analog meter and the IPC digital readout is N O T the actual battery voltage reading..
Its the ignition switch supplied voltage to all the HOT WHEN THE IGNITION IS ON circuits.
To get an accurate reading of the alternator / battery output voltage, you gave to read directly on the battery or you can read the output of the cigar lighter in the dash.
Old Aug 17, 2015 | 09:07 PM
slider_buck
i never have my meter on my when it acts up to get out real quick and measure with a MM. im just going off of the gauge and the display readout. when it drops off like this it def affects the engine. feels like it looses 50 horse
To charging question
