Battery / Alternator question
Old Sep 6, 2015 | 09:06 AM
73Corvette's Avatar
73Corvette
[QUOTE=Bill Curlee;1590352399]I agree! The IPC analog voltmeter & the DIC Digital Voltage reading are NOT giving you actual battery/charging system voltages.
Read the BATTERY & Charging System Voltage directly on the battery terminals.
If you have a 1998 - 2003 C5, the battery cables MUST be properly tightened on the battery. IF, you can move the side terminals by hand,, there TOO LOOSE.
The connection of the BATTERY POSITIVE CABLE to the ALTERNATOR BATT Terminal is not a complete end to end connection.
The POS wire/cable from the battery goes down to the starter SOLENOID main terminal and the BATT Wire (ALT OUTPUT) from the back of the alternator also connects at that terminal on the starter solenoid.
IF,,, that terminal is loose, corroded, damaged burnt,,,,, You will have improper and inconstant charging voltages.
DUDE you were SO right on...
I have to read some of these post over and over, I'm kinda slow, but WAAAAAALLLLAAAAA the lights came on with this post FINALLY.
After re reading it based on the OP's outcome...
Thank you for all that you do for the forum and helping US learn about the C5 and especially the electrical systems...
Old Sep 6, 2015 | 03:27 PM
jdvann's Avatar
jdvann
Getting ready to do this starter replacement today...do I need to drop the exhaust in the rear also or will there be room just disconnecting from the manifolds at the engine? Any other helpful hints appreciated at this point...
Old Sep 7, 2015 | 07:08 AM
dadaroo's Avatar
dadaroo
Just need to remove the exhaust pipes behind the manifolds. Here is a link that might help. It includes a video also.
https://www.corvetteforum.com/forums...-soleniod.html
Mr. Sam
Old Sep 7, 2015 | 11:31 AM
jdvann's Avatar
jdvann
Mr. Sam
Thanks for the link, very helpful info.
Jim
