Electrical Gremlins!
Old Dec 11, 2015 | 04:50 AM
  #101
dadaroo's Avatar
dadaroo
I knew it was in the door, just what I didn't know.
That was brutal. Glad you found it.
Mr. Sam
Old Dec 13, 2015 | 02:14 PM
  #102
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Spoke too soon. Still the same. Sitting in the garage without the engine running everything worked. Once I cranked it up and backed out the passenger window went down by itself and the driver's door controls quit. This really gets old.
Old Dec 13, 2015 | 04:37 PM
  #103
73Corvette's Avatar
73Corvette
WOW
Old Dec 13, 2015 | 05:15 PM
  #104
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The BCM communicates with the LDCM & RDCM through the serial data lines. Pop the top off of the STAR connector that has four wires.
If the BCM is causing the issue, with the top shorting buss removed, the problem should STOP.
If it doesnt, the issues is in the doors or wiring between the doors.
PLEASE try that and see what you get. Post results
Bill
Old Dec 13, 2015 | 10:50 PM
  #105
CaseyJones's Avatar
CaseyJones
I already replaced the BCM but I'll try what you are asking and post back.
Old Dec 14, 2015 | 05:52 AM
  #106
dadaroo's Avatar
dadaroo
Bill
Bill, we have already proved that it will stop if he unplugs C201 in the left A-pillar to separate the door entirely.
Old Dec 18, 2015 | 02:52 PM
  #107
CaseyJones's Avatar
CaseyJones
This thread has become so long and confusing I'm going to start a fresh one and compile all the information.
