Passenger Front Directional Bulb Replacement
Old Sep 14, 2015 | 01:22 PM
BadgerC5's Avatar
BadgerC5
Default Passenger Front Directional Bulb Replacement
I realize this is trivial for many of you but I am new to the Vette scene. I have a 1999 Corvette Convertible and I need to replace the passenger front turn signal bulb. I did some searching on YouTube and found that you "might" be able to get at it through the brake air damn on the front fender. When I tried that, I got my arm and hand stuck.
After looking at it more, it looks like my next option is to go through the tire well but I need to first purchase a low profile jack to lift the car up and remove the wheel.
My question is this, what is the best way to change out this bulb?
Thanks in advance.
Ty
Old Sep 14, 2015 | 01:46 PM
zachaeous's Avatar
zachaeous
Default drl bulb
You can open the headlights and remove the inside cover (three screws Philips head and reach down and remove the socket from there. Be sure and remove the negative battery cable after opening the lights to prevent the lights from closing on you hand. Hope this helps.
Old Sep 14, 2015 | 02:07 PM
BadgerC5's Avatar
BadgerC5
Default Thanks
Very helpful...I will give it a try tonight!
Old Sep 14, 2015 | 04:40 PM
GCG's Avatar
GCG
This post describes the 3 most common ways to do this, and it includes illustrations so you could visualize where you are going.
I do it through the bottom panel, without removing the tire or jacking up the car, although a ramp or a piece of wood to raise it a couple of inches would make it easier
Old Sep 14, 2015 | 05:34 PM
Vanover's Avatar
Vanover
Thanks in advance.
Ty
No ques.is to trivial here,that is what the forum is for.you will get a butthead sometimes,but someone will answer your ques. Welcome to the forum..
Old Sep 14, 2015 | 09:13 PM
BadgerC5's Avatar
BadgerC5
Default Very helpful...follow up question
GCG, this worked great...thanks. I decided to put LED turn signal bulbs in while I was in there...when I tested them they blinked fast as if a light was burned out. Put stock bulbs back in and they acted normal. Any thoughts on why this is happening?
Ty
Old Sep 14, 2015 | 09:28 PM
73Corvette's Avatar
73Corvette
Ty
LED bulbs don't pull enough juice and the car thinks that bulb is OUT...
https://www.superbrightleds.com/blog...perflashing%29
Old Sep 14, 2015 | 09:38 PM
BadgerC5's Avatar
BadgerC5
Default Disregard
Ty
GCG, disregard I found tons of stuff on the forum about the hyperflashing. However, I am still trying to figure out if I can just change out the directionals with LEDs and a Flasher module without affecting the rest of the stock lights. More research...fun though.
Ty
Old Sep 14, 2015 | 09:53 PM
zachaeous's Avatar
zachaeous
Default led
I put LEDs in my front lights only. I did the flasher mod and installed an electronic type flasher and the lights all worked just fine. You can search the forum and find the mod. It is not to hard to do the mod.
Old Sep 14, 2015 | 10:20 PM
GCG's Avatar
GCG
Ty
If you want a plug-and-play solution without having to cut any wire, a hyperflash harness is all you need.
You could also do it yourself with a LED flasher like the one below. It can handle loads from 20mA to 20A without a problem.
Check this out:
Amazon.com: 3-Pin CF-13 Electronic Flasher Relay Fix For LED Turn Signal Light Bulbs: Automotive Amazon.com: 3-Pin CF-13 Electronic Flasher Relay Fix For LED Turn Signal Light Bulbs: Automotive
Old Sep 15, 2015 | 09:40 AM
BadgerC5's Avatar
BadgerC5
Default Flasher
Zachaeous...not sure what you mean by electronic type flasher? The research I did last night showed me that I can change out the flasher module but I did not see anything referencing an electronic type flasher.
Thanks.
Ty
Old Sep 15, 2015 | 10:01 AM
zachaeous's Avatar
zachaeous
Default turn signals
I did a mod that bypasses the hazard flasher in the dash. You cut the wires that go to the hazard flasher for the turn signals and install a electronic flasher there. I got the parts at Auto zone socket and flasher. It took about a hour to do the whole job. Here is a link on how to do this:
https://www.corvetteforum.com/forums...n-signals.html
This does not effect the operation of the hazard flasher it still works and it flashes the led bulbs just fine when activated.
Old Sep 15, 2015 | 07:17 PM
GCG's Avatar
GCG
Check this out:
This is a very clean solution. You can do it yourself like this as well, but you would need to find the connectors to really make it plug-and-play and avoid cutting or splicing cables.
Old Dec 5, 2015 | 11:46 PM
inspector_8's Avatar
inspector_8
7th Gear
The previous owner was charged $85 to change front turn signal bulb. I did it by manually raising headlight, remove hood support/bumper. Reach in unplug bulb CCW. Push it out through brake duct change bulb and reinstall. Actually the bulb wasn't burnt out the connections were bad. I cleaned connectors and a important step is I applied dielectric grease to prevent anymore corrosion or connection problems. I searched this forum and chose the simplest suggestion and it worked great, Thanks.
To Passenger Front Directional Bulb Replacement
