Headlight Actuator-Help
Old Sep 29, 2015 | 02:04 PM
C581's Avatar
C581
Default Headlight Actuator-Help
I've been having some trouble with the original driver's side headlight actuator (part # 16530235LH) on my 2002 convertible. I've replaced the actuator gear twice using two different epoxy glues. Neither glue held the black plastic housing properly causing it to release and the dried glue damaged the new gear. Do any members know the proper glue to use on the black housing? I have GM's replacement for the driver's side headlight actuator (part # 19207409) but have been told the speed of the new motor they use may be slightly different from the original. Any member feedback on that?
Thank You!
Old Sep 29, 2015 | 02:13 PM
runner140*'s Avatar
runner140*
Thank You!
Try contacting someone at Rodney Dickman....they make the kit that contains the epoxy/glue. Mine has held for over four years now.
Old Sep 29, 2015 | 08:50 PM
frsr06's Avatar
frsr06
I've used Rhino Glue with no issues. I've used this same glue to fix my convertible top window. Great stuff.
Old Sep 30, 2015 | 12:51 PM
lionelhutz's Avatar
lionelhutz
There is a gear kit that has a bracket that holds the gearbox together so it won't come apart. Take a search for that kit and either buy one or fabricate something similar.
Old Oct 1, 2015 | 08:52 PM
GCG's Avatar
GCG
Get this kit (pay attention because there are 2 different kits: one for "97 to early 2000" and another for "late 2000 to 2004"). The second one includes the reinforcing bracket mentioned above.
There is a TSB, that calls for shimming the driver's side motor. The parts needed for this are also included in the kit.
To Headlight Actuator-Help
