Headlight problem
Old Oct 3, 2015 | 04:19 PM
Rick Jeffreys's Avatar
Rick Jeffreys
1st Gear
Default Headlight problem
After replacing the motors on my C5 the left one works properly and nothing from the right one. However, when I take the left side lead and plug it into the right headlight it goes up and down as it should.
What do I need to check? I'm baffled.
Old Oct 4, 2015 | 09:00 AM
Promusicrick's Avatar
Promusicrick
8th Gear
Originally Posted by 8VETTE7
Of course you looked in the back of the owners manual at the fuse box layouts to find out that fuse #3 (engine compartment fuse box) is for the right head light motor and fuse 34 was for the left headlamp motor and that they were both good. Right?
Yes, that's the first thing I checked---even reversed them--both are good. Thanks
Old Oct 4, 2015 | 01:19 PM
lionelhutz's Avatar
lionelhutz
You're saying both motors work but the power wire for the right side won't run a motor? Did you take a good look at the connector and make sure you didn't damage anything?
8VETTE7 - Your wire descriptions are not very clear. Both wires always get used. One is power and the other is ground and it switches depending on the direction. I think what you're saying is that the light colored wire has power when going up and at the same time the dark colored wire would be grounded. The opposite would be true when going down.
Old Oct 7, 2015 | 09:00 AM
Ronnie_W's Avatar
Ronnie_W
Has it been repaired
Old Oct 7, 2015 | 09:19 AM
runner140*'s Avatar
runner140*
And the problem was????
To Headlight problem
