Zero oil press
Old Oct 14, 2015 | 11:00 PM
zz28zz's Avatar
zz28zz
Default Zero oil press
Stopped at my local gas station and filled-up. Started the eng up and got the warning saying service eng soon. Hit reset button to see the digital readout. It looks like this: "Oil Press XXX"
Checked the analog gauge and it's at zero.
Shut it off after less than 10 secs run time.
Pull dipstick and it's full.
Started eng again and revved it a little (abt 2k rpm). Mechanical gauge got up to abt 40 psi then quickly dropped off again to zero. Shut off eng after abt 5 secs.
I was only abt 1 mile from home but I didn't want to risk it. Called a flat-bed tow truck and now it's in my shop.
Eng has 110K easy miles and has never been raced or taken apart (other than removing the intake abt a year ago). Been running Valvoline full synthetic and changing it when computer says it's getting close. Eng sounds fine. No weird noises at all.
Are there 2 oil press sensors? One for the analog gauge and a separate one for the digital readout? I know there's one behind the intake. I've replaced it twice due to leakage.
Old Oct 20, 2015 | 09:29 PM
zz28zz's Avatar
zz28zz
Replaced sensor and all is well.
Thx 8VETTE7
Old Oct 20, 2015 | 10:36 PM
73Corvette's Avatar
73Corvette
Glad it was just the sensor... thanks for posting your outcome...
Old Oct 22, 2015 | 05:56 PM
Paul 75 L82's Avatar
Paul 75 L82
A tow is sure cheaper than a motor.
Old Oct 22, 2015 | 06:33 PM
racebum's Avatar
racebum
pushrod v8s give you a BIG warning if you do indeed have no or low oil pressure. you will hear what sounds like a box of marbles rattling. the lifters can't operate without oil pressure and you will hear clanging like no other
To Zero oil press
