C1241 Magna Steer Circuit Malfunction
Old Oct 19, 2015 | 03:48 PM
TTvet's Avatar
TTvet
Default C1241 Magna Steer Circuit Malfunction
Hi there folks!
I just got a C1241 magna steer error code in my 1997 C5 while driving on the freeway.
The steering suddenly got a lot stickier as well.
Could this be due the leaking steering rack or is there something else I should be looking?
Could it be the ABS sensor in the front wheel?
Thanks!
Old Oct 20, 2015 | 09:24 AM
dadaroo's Avatar
dadaroo
Here are the diagnostics to review as a starting point.
https://www.dropbox.com/s/dy2t6b4v3j...C1241.pdf?dl=0
Mr. Sam
Old Oct 20, 2015 | 10:22 AM
TTvet's Avatar
TTvet
Thanks a lot Mr. Sam!
Old Oct 20, 2015 | 11:20 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
As far as I know,, 97 & 98 EBTCMs contain the MAGNASTEER components. There is a dedicated relay inside the module mounted to the circuit board.
Im at work and can not use Sams DROP BOX to view the circuit.
Use the troubleshooting guide and figure out what is missing.
BC
Old Oct 20, 2015 | 04:32 PM
TTvet's Avatar
TTvet
Bill, thanks very much!
Yes, I'm trying to figure out the problem with the help of Sam's file.
Olli
Old Dec 1, 2015 | 11:00 PM
Crussader's Avatar
Crussader
Did anyone get this diagnosed? I am having the same issue on my '98 and was about to create a new thread when I found this.
Old Dec 2, 2015 | 12:00 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ah,,,,, You have the schematic & the TROUBLESHOOTING Procedures. Can you use a METER?
You need to check:
The connector/pigtail on the steering rack, the connector (specifically the FEMALE PINS for damage/spread apart) and you can check voltage and ground at the harness from the EBTCM.
CHECK THE RESISTANCE OF THE COIL IN THE RACK!
Bill
Old Dec 2, 2015 | 12:25 PM
Crussader's Avatar
Crussader
Unfortunately, this is beyond my skill level. Just basic wrench work for me. However, this is useful info to have when I take it to the shop. Thanks!
Old Dec 18, 2015 | 04:57 PM
TJ57's Avatar
TJ57
2nd Gear
Default C1241 Magna Steer Circut Malfunction
I have a 2002 ZO6. I have a C1241 code that comes back after I remove it. I took it to a local shop that said the EBCM needs to be repaired. ABS Fixer said a repaired EBCM would not fix code C1241. Is this true?
Old Dec 18, 2015 | 10:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Brother,,,, You need to do a little SELF Diagnostics investigation... Start with the connector on the rack. Is it properly connected and in good shape??
Go look at it and see if the wires are damaged and or the pins in the connector are in good shape.
You will more than likely be asked to take some voltage and resistance readings at that connector. BE PREPAIRED to do that. Get a meter and learn how to use it to get the raw data.
Bill
Old Dec 19, 2015 | 02:11 PM
TJ57's Avatar
TJ57
2nd Gear
Bill
Thanks Bill, I originally checked the wires and connector. They looked good, however I did not take any meter readings. It's in an independent repair shop now anyway, so I am going to let them deal with it.
Old Dec 26, 2015 | 08:06 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any update?
To C1241 Magna Steer Circuit Malfunction
