Starting issue
Starter solenoid. Next place to check. MUST be clean and tight!! Wires in good shape!!
IF,,,,,,,,,,,,,,,,,,,,,, all that checks out good,,, Have someone HOLD the key to CRANK while you APPLY SOME EXTERNAL AGGETATION to the solenoid/starter. IF,, the whack causes the starter to crank, you need a new solenoid and or starter. The solenoids are well known to fail but, you have to remove the starter to replace the solenoid...
Best picture I could get with header still on.
Yeah, I went and looked at the starter the best I could without taking header off, the one connection I could feel was tight on there. Well I cleaned the contacts in the ignition block about a year and a half ago, so I mean I guess it couldn't hurt to take a look at it again.
You MUST determine if the TDR is being powered when you turn the ignition switch and complete the safety circuit . (Depress the clutch or have it in PARK/N)
IF,,,,,,,,,, the TDR CLICKS when you turn the key and complete the safety circuit, that relay closes a heavy duty contact which supplies 12 VDC @ 60AMPS to the starter SOLENOID.
SO,,, If the TDR is actually being powered by the lower current control side of the relay and CLICKS, and the starter doesn't work, you have to figure out if the solenoid is getting the 12 VDC 60 amp power from the high current output side of the relay.
If the solenoid is getting the 12 VDC 60 amp power and isn't powering the starter motor,,, Thats where that THUMP THE SOLENOID comes into play!!
Bad low oil pressure sensor or real no oil pressure
Faulty column lock
Faulty fuel pressure sensor or no real fuel pressure
Faulty anti theft device
The car doesn't care if there is oil pressure and there is no fuel pressure sensor.
