steering rack rebuild?
Old Nov 11, 2015 | 03:09 AM
StealthFRC's Avatar
StealthFRC
Default steering rack rebuild?
is the steering rack rebuildable? are the parts offered to the public? both sides of mine seem to be leaking pretty bad, wondering if i need to order a new one and send my core or if its something i could do
Old Nov 11, 2015 | 04:14 AM
don37's Avatar
don37
Veteran: Canadian Forces
After researching this heavily, i would say yes - most probably by a remanufacturer. My concern was not seals but quality of interface between rack and pinion gear. All options seemed not to readily address this.
Various options available. I was even willing to try an early gen c6 unit. I archived these 2 options (didnt buy as i got a new car....)
Napa - 361232 - http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Power-Steering-Rack-Pinion-Complete-Remfd/_/R-PNB361232_0333882179
Steering rack
http://www.ecklerscorvette.com/corvette-rack-and-pinion-remanufactured-1998late-2004.html
Old Nov 11, 2015 | 08:59 PM
StealthFRC's Avatar
StealthFRC
crazy how much they cost.
Old Nov 12, 2015 | 07:10 AM
ericdwong's Avatar
ericdwong
I recently replaced mine with a remanufactured unit. Here's the cheapest one I found. It seems to be good quality... (there is a core exchange)
http://www.zip-corvette.com/catalog/...emanufactured/
Old Nov 12, 2015 | 07:29 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I believe there is (or was...) an outfit going by the name of 'Turn One', that was doing performance oriented, rack and p/s pump rebuilds.
Old Nov 12, 2015 | 11:31 AM
NemesisC5's Avatar
NemesisC5
http://www.turnone-steering.com/#!re...-services/cp52
Old Nov 12, 2015 | 11:52 AM
DJROBJ's Avatar
DJROBJ
Try Lares. I've had various steering and suspension pieces and parts rebuilt by them over the years for other cars. Not sure if they do C5's, but they are a reputable company to inquire upon.
Old Nov 17, 2015 | 12:00 PM
Leo333's Avatar
Leo333
6th Gear
Check with vettenuts, they may have a used one or rebuilt.
www.vettenuts.net they are out of TN. Good luck
Old Nov 17, 2015 | 01:07 PM
StealthFRC's Avatar
StealthFRC
thanks guys, ill most likely just go down to my local napa or advanced and see what they go for. i have a parts hook up thru them so we shall see.
its to bad that the seals etc are not available, I'm sure its a pretty easy job. i was hoping to not have to pull the rack out and just change the leaking seals... oh well.
Old Nov 17, 2015 | 02:40 PM
lionelhutz's Avatar
lionelhutz
I don't know a source for parts but Zip Corvettes will sell you an exchange rack for $220. It was the cheapest deal, and still could be. I haven't read of anyone having problems with their rebuilds. Mine is working fine.
Old Nov 17, 2015 | 03:58 PM
SaberD's Avatar
SaberD
I'd be really interested to see what is involved in rebuilding the rack with some pictures.
Old Nov 17, 2015 | 06:27 PM
corvettefrance's Avatar
corvettefrance
steering rack is one of the weakness of the C5. My car is at 19,000 miles and I am at my 4th. Unfortunately GM does not sell them anymore so my last one is ZIP corvette
However it will be interesting to see if "turnone" can make a customized stronger steering
Old Nov 17, 2015 | 10:54 PM
lionelhutz's Avatar
lionelhutz
There's something wrong if you're installing a rack every 6-8k miles....
Old Dec 28, 2015 | 01:21 AM
StealthFRC's Avatar
StealthFRC
i ended up going with the one from zip corvette. I've installed it but its winter now so won't have any road time for a couple months.
i tried getting one from auto zone, advanced auto parts, and napa... none of them are available anymore.
Old Dec 29, 2015 | 07:44 AM
vettenuts's Avatar
vettenuts
Does Zip do them in house? I believe that they do some of their re-manufactured parts in house but not sure on this one. I personally would trust a rack from Zip as opposed to the box stores link Autozone or Advanced.
Old Dec 30, 2015 | 12:55 AM
StealthFRC's Avatar
StealthFRC
all they do is replace wear items, its not like they actually make the steering racks. they are all original cores that get seals etc replaced so i wouldn't have an issue purchasing from advanced etc, plus they are local so if there is an issue its much easier to deal with them, but it doesn't matter since they no longer can get them.
Old Dec 30, 2015 | 07:47 AM
vettenuts's Avatar
vettenuts
That's what I thought when I purchased a rebuilt part by Dorman for my daughter's Jeep, boot gave out within a year. Parts used were Chinese junk.
Old Dec 31, 2015 | 06:40 AM
vettenuts's Avatar
vettenuts
I e-mailed Zip about the rack rebuild, response is below:
Thank you for taking the time to write Zip Products. These racks are not rebuilt here in house, so I can only say that our rebuilder is using the OEM machines and tools which were used in the original production of the racks. They are also tested on the same equipment used at the OEM. However there is not a way to replace or repair a rack with a bad column sensor magnet.
If you are road racing, the TurnOne units are going to be a better option. The standard OEM racks are not really heavy duty enough to withstand the continuous loading of real down force and the grip that slicks provide. Certainly people do use the OEM racks, however they just won't last as long. As usual, your mileage may vary. Our warranty does not cover cars used on track.
To steering rack rebuild?
