Oil Pressure Question
Try this. Set the DIC to display something other than the vehicle mileage, say engine temp or oil pressure etc.. Then start the engine and once running see if the DIC is displaying mileage again. If so then the battery is very suspect. While it can crank the engine, it is not retaining enough voltage to support the memory.
If you put a DC Voltmeter on the battery terminals and monitor it before, during and after COLD cranking the engine, you will see what we are talking about. I bet it momentarily drops below 9 VDC when you first hit the starter.Each time it drips below the operational voltage level of any of the cars modules, it causes them to shut down. This can adversely effect some relays and electrical components. It can also cause your emissions ready flags to reset and the car will not pass emissions until you drive the required driving cycles.
Check you DTCs and I bet your LDCM & RDCM have low voltage DTCs
YOU COULD HAVE ANY OF THESE Battery out of range DTCs
B0846, B0851, B2282, B2283, B2284, B2285
Does the car have headers?? If yes then check ALL the connections at the starter. Lots of recent threads by posters who have had poor/loose or burnt connections at the starter. Check the negative battery cable connection at the block while you are at it.
