Power Antenna Replacement
Old Nov 13, 2015 | 05:10 PM
MightyMike's Avatar
MightyMike
Default Power Antenna Replacement
Guys, I tried doing a search for this but how can I replace my non functional power antenna with a fixed mass unit?
I originally thought that the FRC's came with a fixed antenna... Not mine.
Please point me in the right direction. Stuff like this drives me crazy.
Old Nov 13, 2015 | 05:24 PM
JR-01's Avatar
JR-01
If the motor runs you can easily replace the mast for about 15 bucks. The teeth wear out on the gear cord.
Old Nov 13, 2015 | 06:32 PM
MightyMike's Avatar
MightyMike
How do I get the fixed antenna back?
Old Nov 13, 2015 | 10:48 PM
grantv's Avatar
grantv
Originally Posted by 8VETTE7
The replacement mast is available from several sources, one being Mid America. The base that it mounts to is another issue altogether. I suspect it is NLA from GM but I might be wrong. Could try a salvage yard or Marc at Vettenuts. They have a website:
https://www.vettenuts.net/
I think the Z06 was exactly the same in that it came with the fixed mast from the factory...
Yep, fixed mast antenna on the Z model to save weight. Very tall; think it was built for ham radio ops or communicating with aliens.
Old Feb 8, 2023 | 05:25 PM
Naylin's Avatar
Naylin
the mast wont come free. it appears stuck. how do i get it out if it is stuck please.
cheers
Naylin
Old Feb 8, 2023 | 07:44 PM
yellow2007's Avatar
yellow2007
cheers
Naylin
I replaced mine last month. I assume you are talking power antenna?
Old Feb 8, 2023 | 08:05 PM
1999corvettels1's Avatar
1999corvettels1
I need to fix mine also, been stuck up over 3 years and hear the motor run.
Gonna go look on rock auto to see if they have it.
Old Feb 8, 2023 | 10:47 PM
rrwirsi's Avatar
rrwirsi
After you replace/fix the antenna, you may want to consider doing this:
Wireless switch for power antenna - CorvetteForum - Chevrolet Corvette Forum Discussion
After install, I found the radio works just fine in the down position when in non rural areas and it stops the antenna from going up when playing CD's.
Old Feb 10, 2023 | 10:40 PM
Turk05's Avatar
Turk05
My antenna started to stick, and I found out you can drill the fastener points on the antenna case, and get to the mechanism. It's really simple, and I found mine was nasty chunky dirty inside. Cleaned it, new lithium grease, reassembled with screws to replace the drilled plastic fastener points, and it works like a champ. Enough dirt in the mechanism will jam the mast, even ff the motor runs.... You access it through the rear taillight holes. Best of luck...
Old Feb 11, 2023 | 08:16 AM
yellow2007's Avatar
yellow2007
As an aside, if you have the power or retractable antenna, never use oil or wd40 to lubricate the mast. Use isopropyl alcohol
Old Feb 11, 2023 | 12:16 PM
jackthelad's Avatar
jackthelad
Lots of stuff here:
https://www.mamotorworks.com/corvett...-hardware-1915
Old Feb 11, 2023 | 12:39 PM
Hary Gahtoe's Avatar
Hary Gahtoe
I can’t say I care listen to anything I need an antenna for. No more talk or commercials.
I have Apple CarPlay and Bluetooth so I get better music and Nav and the OE antenna is unplugged. Kind of like ashtrays. It’s there but not needed anymore
Old Aug 5, 2023 | 05:57 PM
kwiki's Avatar
kwiki
4th Gear
Where did you find the replacement antenna?
Old Aug 6, 2023 | 08:46 AM
Moved to C5 Tech.
To Power Antenna Replacement
