Dash, tail, interior lights won't go off
Old Nov 15, 2015 | 01:31 PM
Raemer74's Avatar
Raemer74
3rd Gear
Default Dash, tail, interior lights won't go off
2002 z06, cannot get everything to turn off, had to disconnect the battery to turn it off. Hook it back up, same issues. Recently had ignition replaced, not sure it's related to that, but I haven't used the lights since they performed the work.
Appreciate my suggestions on where to start
Old Nov 15, 2015 | 02:03 PM
Raemer74's Avatar
Raemer74
3rd Gear
Forgot to mention headlights are on also. Everything that should be on when switch is on stays on
Old Nov 15, 2015 | 03:20 PM
c4cruiser's Avatar
c4cruiser
If you have the owner's manual, look at Page 2-100. Pressing the "Options" button will allow you to set how some of the lights work as you approach the car and using the fob to unlock the door or to lock it after exiting.
Press the Options button and repeat until the "Approach Lights" menu appears on the DIC. This will allow you to turn on the fog lamps, front turn signals, back-up lights and courtesy lamps. The lights will be controlled by a timer and it's possible that the time is not working so the lights won't go off.
Headlights are also controlled by the Twilight selection. This will turn the headlamps on when it's dark outside. It will also turn the dash lights on.
Old Nov 15, 2015 | 04:17 PM
Raemer74's Avatar
Raemer74
3rd Gear
Multi function switch was bad, you can turn the switch but it doesn't rotate the helical gear. Rotated the contact gear by hand, reinstalled, and the lights went off. Guess I have a part to order.
Thanks for the input
Old Nov 16, 2015 | 07:14 AM
dadaroo's Avatar
dadaroo
Just read this post. I assumed it was the MF switch and then when you said the HLs were on I felt it was definitely the MFS.
Here is some DIY for you.
https://www.corvetteforum.com/forums...-a-how-to.html
Mr. Sam
To Dash, tail, interior lights won't go off
