Best C5 Shocks
YES! If you have the F-45 or F-55 systems you would have to remove that RPO Option out of the Body Control Module (BCM) before you can install a normal shock (of any brand)
To remove the RPO, you would need to use a GM TECH 2. It is the only way to communicate and program the BCM. The procedure is very straight forward and easy to preform with the TECH 2.
Bill
Bill
If you look back at earlier posts you find that there is a year when they made the switch-over. Some feedback has indicated that it may have been done in the middle of a model year but that seems hard to believe. So check that out and you'll get your answer.
Another way is to look at the RPO codes in the glove box. There is a different code for 45 and 55. I'm not sure what they are so again further research on the forum will find you the answer.
Another way to go if you can't get access to a Tech II, which was my case here in Maui Hawaii, so I went with the plug in simulators which create a feedback loop to the Ride Control Module in the trunk which creates an artificial sensory condition of the basic ride setting. Then you can replace the shocks with anyone's setup. Several of the Forum supported vendors provide the simulators and they are quite reasonable. Only warning I'll pass on is be sure the shop is competent in doing this work and puts a tiewrap loop around the plugin. I had one of mine come off and it caused me to go into limp mode. That wasn't fun because I was at an autocross when it happened.
After doing the simulators, I then figured a way to replace the console switch to remove the dial. That, in essence, was creating a feedback simulator from parts you can buy from several suppliers. And replacing the switch cover with one without the dial.
Last points: Cultrag sells a nice package, but it's not the only one available. After comparing feedback: C5, Bilstein, and several others,; and since my car was lowered (which limits your choices), I chose the Pfadt Johnny O'Connell set up for my 02 C5. Very happy with choice for both driving and autocrossing, but not so good for drag racing. No real weight shift when coming off the line, so I use the traction control to avoid excessive wheel spin. Probably not as fast as I'd be with a set of 90/10 drag shocks, but it is consistent.
For certain you should pay heed to his recommendation of doing the sway bars as well. That's where you get the ability to "tune" your handling.
Hope this experience is helpful from an owner who faced the very same questions you have. Good luck.
professor jim
https://www.corvetteforum.com/forums...rformance.html
2013 C6 Z06 Shocks!
We sell the 2013 C6 Z06 shocks for $294.94 Many C5 customers ask us why we don’t recommend the 2004 shocks over the 2013. Many people also say that the C6 shocks are only developed for the C6. If you look at all of the basic suspension components between the C5 and C6, they are very much the same. The reason we don’t recommend the 2004 Z06 shocks over the 2013 C6 Z06 shocks is simply because of the price and customer feedback. We have many customers who have tried both sets of shocks and cannot tell the difference between the two, so why not purchase the lesser expensive set!
For the C5, not C5 Z06, we also recommend the C6 Z51 sway bar kit. The C6 Z51 sway bar kit coupled with the 2013 C6 Z06 shocks is our most popular suspension and handling upgrade for the C5.
To order, please call 484-949-2099 or go to the link below to order!
http://www.cultragfactoryparts.com/c...t/c6z06shocks/
||--Genuine GM 2013 C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
25819268 – Z06 Rear Shocks
Both sets of front and rear shocks (4) $294.94 total.
For the shocks on our website, use part number c6z06shocks.
The C6 Z06 shocks will work on stock C5’s and C6’s without modification.
Thank you,
Did the same to mine(C6 Z06 shocks, Z51 sways and new end links) and had the dealer lower mine to the bottom of the stock bolts. (they have a Corvette only tech ) Rides and handles great.
