Best C5 Shocks
First time posting here in the CF. Been lurking as a guest for years and had a 2005 GTO before this. So this is nothing new to me.
I was wondering what the best shocks are for a 1997 C5. I already have Hotchkis front and rear sways. I'm at about 120k miles and though the shocks still work they are soon to be on their last leg. I prefer my suspension to be stiff as crap. I don't go to the track so I have no reason to go with coilovers, but I do fly through twisties and want the car to stay planted and firm. Any advise would be appreciated gents.
Good luck... GUSTO
However I believe that when you change the shocks from the base models you MUST have someone with a TECH II or similar software to eliminate all the codes and error messages they will produce----You can research this here on the forum--It can be a tedious job !!!
IF you decide not to go thru all the re-programming issues caused by a shock change--there are other mods that will make your car run flatter and stiffer in the turns
1. Larger sway bars (Z06)
2. Poly bushings on all the sway bars
3. Metal end links rather than the stock plastic ones
4. SOLID rear trans mount
These would be my 1st set of mods before going thru the trouble of a shock change---See how well it works for you---If not satisfied THEN think about the shocks
Good luck... GUSTO
And IMO, the C6 Z06 shocks are a good replacement when the time comes.
Have used Konis for years on several autocross cars and never had a quality issue.
Koni's are probably the best you can get without going coil over. That comes at a price premium however.
That being said, I pushed my 02 ZO6 hard around a long sweeping highway entrance ramp and there were some uneven places on the pavement. The suspension lost its ability to control the tires on the pavement and the car started to skidder sideways off the turn.
BOY,,, THAT was a butt pucker moment!!!
I replaced the OEM C5 ZO6 shocks at 35,000 miles with new GM C6 ZO6 shocks and I was amazed at the improved high speed maneuverability of the car. That same entrance ramp is a piece of cake now!!!
The car is solid as a rock now. There was NOT a significant increase in normal daily driving road harshness or noise with the C6 ZO6 shocks. Good price and excellent performance!I got mine from Gene Culley.
DO SHOCKS CHANGE THE CARS RIDE HEIGHT??
Well,,,,,,,, Each shock has approx. 40-50 pounds of FORCE (Im giving it a good estimate!!) on the shock rod. Compressing the rod into the shock is tough. I turn my new C6 shocks up-side down and body weight the rod into the shock and then use a coat hanger wire to keep it compressed! Cut the wire when I have it in place.
If you had four friends exert 50 pounds of lifting force on each corner of the car, your car will increase it STANCE/ ride height by some amount. So, the answer to that question is YES, it will but,, not to a significant degree. You can always adjust the ride height back down by using the front spring adjusters and increasing the bolt length on the rear spring to arm connector bolts.
I would bet a cold one that your OEM shocks have ZERO nitrogen charge now and little or no dampening ability.
Bill
https://www.corvetteforum.com/forums...rformance.html
2013 C6 Z06 Shocks!
We sell the 2013 C6 Z06 shocks for $294.94 Many C5 customers ask us why we don’t recommend the 2004 shocks over the 2013. Many people also say that the C6 shocks are only developed for the C6. If you look at all of the basic suspension components between the C5 and C6, they are very much the same. The reason we don’t recommend the 2004 Z06 shocks over the 2013 C6 Z06 shocks is simply because of the price and customer feedback. We have many customers who have tried both sets of shocks and cannot tell the difference between the two, so why not purchase the lesser expensive set!
For the C5, not C5 Z06, we also recommend the C6 Z51 sway bar kit. The C6 Z51 sway bar kit coupled with the 2013 C6 Z06 shocks is our most popular suspension and handling upgrade for the C5.
To order, please call 484-949-2099 or go to the link below to order!
http://www.cultragfactoryparts.com/c...t/c6z06shocks/
||--Genuine GM 2013 C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
25819268 – Z06 Rear Shocks
Both sets of front and rear shocks (4) $294.94 total.
For the shocks on our website, use part number c6z06shocks.
The C6 Z06 shocks will work on stock C5’s and C6’s without modification.
Thank you,
