voltage drop after pothole incident
Old Dec 5, 2015 | 07:27 PM
t56mike's Avatar
t56mike
Default voltage drop after pothole incident
Hello guru's! I need some advice. I hit a pothole pretty hard last night with the passenger side front tire. After that my voltage started dropping till it got to 10. I couldn't restart without a jump. Battery is 12.7 volts disconnected and 12.7 connected. Yet the dash shows 10 volts. You jump start it and the gauge starts dropping till dash shuts down at 8 volts. The alternator is putting out 14 volts and the battery is really at 8 volts when running. I have a feeling I messed up my starter solenoid when I smacked that pothole.
Old Dec 5, 2015 | 11:12 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The IPC digital voltage readout and the IPC Analog meter DOES NOT read TRUE battery voltage.
It reads the voltage output of the IGNTION SWITCH for the HOT IN RUN and START circuits.
I recommend that you examine the ignition switch for proper battery voltage output.
Each module that has multiple battery voltage inputs uses direct battery buss input and IGNITION SWITCH (ON) input.
If the ignition switch ON/RUN voltage is low,, that is the issue you are seeing.
Bill
Old Dec 6, 2015 | 02:08 PM
lionelhutz's Avatar
lionelhutz
Yes, if the alternator voltage is 14V while the battery voltage is 8V, then there is no connection between the alternator and the battery. Examine the wire from the alternator to the solenoid, the fusible link at the solenoid and the connection at the main solenoid post for damage.
Bill
In a few of the service manual documents I've been looking at, they show the voltage gauge is using serial data from the PCM. It is likely still the ignition switched voltage but it didn't appear the gauge read the voltage directly.
Old Dec 6, 2015 | 04:18 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats the question that the OP needs to answer.
Where are you reading or observing BATTERY VOLTAGE from? The IPC gages or directly on the battery terminals.
IPC FUSE 18 Is the HOT IN ON & START feed (from the Ignition Switch ) that powers the IPC Analog & Digital meters. -
Old Dec 7, 2015 | 12:20 AM
t56mike's Avatar
t56mike
I fixed it! The leads on the starter solenoid were loose and corroded. The jar from the pothole was the final straw since I found that the nut was only hand tight. I had ohmed out the lead from the battery positive terminal to the alternator and it showed open. After cleaning and tightening the leads i got .3 ohms. The voltmeter now reads a steady 13.8 with the engine running. Thanks for the help everyone.
Old Dec 7, 2015 | 12:22 AM
t56mike's Avatar
t56mike
If this didn't work then it was time to open up the ignition switch and start hunting.
Old Dec 7, 2015 | 09:22 AM
CactusCat's Avatar
CactusCat
I love happy endings! Time to get back to driving!
To voltage drop after pothole incident
