Window Regulator
Old Dec 7, 2015 | 12:41 PM
DNAST1's Avatar
DNAST1
2025 C8 of the Year Finalist - Modified
2023 C5 of the Year Winner - Modified
2023 Corvette of the Year Finalist (C8) - Modified
2023 Corvette of the Year Finalist (C6) - Modified
2022 C8 of the Year Winner - Modified
2022 C6 of the Year Winner - Modified
Default Window Regulator
Anyone have experience with the aftermarket regulator on amazon vs oem? Huge price difference. Thx
Old Dec 7, 2015 | 12:50 PM
Christian327's Avatar
Christian327
I bought my regulator via amazon, they work perfectly but they werent aftermarket though.
Amazon.com: ACDelco 10344131 GM Original Equipment Front Driver Side Power Window Regulator and Motor Assembly: Automotive Amazon.com: ACDelco 10344131 GM Original Equipment Front Driver Side Power Window Regulator and Motor Assembly: Automotive
Old Dec 7, 2015 | 01:43 PM
pmr2000's Avatar
pmr2000
After my experience with Autozone wiper motors I'd go with AC Delco....don't want to do the labor 2x!
I need the same my left if crunchy on the way down, took the door panel off some lube made it a bit quieter but guess its another part that won't last the life of the car.
Old Dec 7, 2015 | 03:17 PM
DNAST1's Avatar
DNAST1
Ditto. Been nursing mine now for than a year. Not DD. Now really
grinding !
Thx for replies
Old Dec 7, 2015 | 03:20 PM
pmr2000's Avatar
pmr2000
So how long before failure once the grinding starts? Probably should just replace now, hate to get stuck with window down!
Old Dec 30, 2015 | 01:50 PM
Russ529's Avatar
Russ529
Default c5 window regulator
I have an excellent 2001 c5 passenger side window regulator for sale.
Also, glass and all door parts and wiring.
Best offer for any of the parts.
Old Dec 30, 2015 | 02:14 PM
DNAST1's Avatar
DNAST1
I have already bought driver's side. Thanks anyway.
Old Jan 13, 2016 | 03:54 PM
Paul Wood's Avatar
Paul Wood
I recently had the same issue. I purchased from Southern Car Parts. It was a refurbed part but it was $99 and worked perfectly. I would recommend them 100%. Good luck.
Old Jan 15, 2016 | 11:25 AM
SG Lou's Avatar
SG Lou
Not exactly C5 related but.............the passenger side regulator went out on my 03 Silverado. Replaced it with an aftermarket version i got off of Ebay. Noticeable difference in the speed of it going up and down verses the OEM unit on the drivers side.
Old May 27, 2017 | 04:58 PM
alex1038's Avatar
alex1038
1st Gear
Purchased an aftermarket regulator from 1AAuto.com. Worked well for 60 days, then stopped working today. I'm waiting to see the response since it is still under warranty. Worked perfectly until today.
Old May 27, 2017 | 06:29 PM
SG Lou's Avatar
SG Lou
Get a AC Delco replacement unit and forget about it.
To Window Regulator
