has anyone used ecklers torque tube couplers? the GM ones seem way overpriced to me. Ecklers has some for $45 but i wonder how well they are holding up.
This is just an observation and quite a bit of experience with no intention to insult any supporting vendors...
Vendors sell a wide variety of products from many sources. I've purchased repackaged name brand items with similar prices available from local parts houses to cheap Chinese reproductions that I was afraid to install. This statement includes anything from hard parts to trim screws. I bought a complete set of front end rebuild parts for my C3 that had both Moog and no-name parts in the same box. Guess which ones I had to replace after a year of occasional driving?
If a part is significantly cheaper than a known good part, such as the GM couplers, I tend to be skeptical of the long term quality any more. It's a case of buyer beware.
If it were a quick replacement part that could be easily changed if it failed, then I might be willing to try the part. However, given where the couplers are located and how much work it is to get at them, I would go with the best part you can find. That is a job I wouldn't want to do twice.
I replaced my clutch myself and it is not an easy job. That being said I would buy the best couplers I could find regardless of cost if I needed them. I wouldn't want to do this job twice.
Is there any consensus on which replacement is the best? Best in my mind has more to do with longevity than smoothness.
I have a set of Gm 12mm rubber couplers that were installed and never driven on (I opted for the solid aluminum ones for race car)
