Help on engine mount brackets
Old Dec 30, 2015 | 12:58 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by fasttoney
I reused my crank, and cam from my ls1. And just got forged pistons, rods, and ls2 block. So i just need the cam sensor extension, and the knock sensor extensions?
Yup, that should do it.
IF however, you decide to change the intake manifold and TB (such as a F.A.S.T. w/ an LS2 TB for example), then of course you'd need the appropriate adapter wire harness for that as well. Racetronix covers that as well. Plug-n-play.
Personally, I would also take this opportunity to relocate your OPS. You can search and there's a couple people still offering them. They use stainless braided hose, etc. Very worthwhile.
Sadly, the absolute best version is one that was made by Total Performance Engineering (TPE), which is no longer in business. It did NOT use a stainless braided hose and instead used a machined aluminum adapter block that bolted directly to the side of the block next to where the oil filter is located. Beautiful piece of work and works like a charm. Sometimes you can get lucky and find one for sale in the for sale section.
HTH
Btw, I would also recommend installing a Powerbond (race series) harmonic balancer w/ARP crank bolt, over going back with an OE. They are excellent value for money and are reliable. If you don't want to use the underdrive version, they make an identical version in standard diameter size as well.
Old Dec 30, 2015 | 02:48 PM
fasttoney's Avatar
fasttoney
I just ordered an ati super damper, with 10% under drive. Whats ops?
Old Dec 30, 2015 | 03:14 PM
fasttoney's Avatar
fasttoney
ops, oil pressure sending unit. got it. thanks again.
Old Dec 31, 2015 | 11:40 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What engine mounts are you using?? I recommend up-grading to a poly replacement and if that's not an option, at least a set of NEW OEMs.
LoneStarFRC EXCELLENT INFO AND HELP!
Bill
Old Dec 31, 2015 | 03:14 PM
fasttoney's Avatar
fasttoney
Bill who sells the poly? How they compare to oem?
Old Dec 31, 2015 | 03:21 PM
Smoken1's Avatar
Smoken1
Here ya go
http://hinsonsupercars.com/p-1355-hi...-corvette.aspx
Old Dec 31, 2015 | 03:28 PM
fasttoney's Avatar
fasttoney
Smoken1 thanks. Any vibrations a idel? Are you using these?
Old Dec 31, 2015 | 03:37 PM
Smoken1's Avatar
Smoken1
I have a set of them but have not put them in. It's been to darn cold up here and I only have a carport.
Old Dec 31, 2015 | 03:46 PM
fasttoney's Avatar
fasttoney
Ok. I see. Maybe ill do a fresh oem set.
Old Dec 31, 2015 | 04:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Price: $495.00 LOL!!! OUCH! Check around,, Im sure there are some for less.
BC
Old Dec 31, 2015 | 04:23 PM
Smoken1's Avatar
Smoken1
Yea $495.00 is an Ouch! I got mine in the F/S section when someone went to the Pfadt set-up
Old Dec 31, 2015 | 04:45 PM
LoneStarFRC
GM 15254700
The units made by either DEA or Anchor are much less expensive than Delco. AAMOF, it's DEA and/or Anchor that are the actual manufacturer for GM. Check Rock Auto or other sources for DEA A2993 or Anchor 2993. Another company Westar offers a solid (non-hydraulic) version of the OE mounts too.
Old Jan 1, 2016 | 02:43 AM
  #33
fasttoney's Avatar
fasttoney
Thanks guys, I appreciate all the advice. Happy New Year.
Old Jan 1, 2016 | 03:20 AM
  #34
LoneStarFRC
HNY!
