Problem with speedometer C5 2000
Old Dec 28, 2015 | 02:41 PM
janchuck's Avatar
janchuck
Default Problem with speedometer C5 2000
Speedometer stopped working. HUD also shows no speed reading. Odometer does not operate. Also, cruise control no longer works.
Old Dec 28, 2015 | 04:05 PM
SPEED750's Avatar
SPEED750
Any codes on the DIC ? Maybe a speed sensor issue.
Old Jan 5, 2016 | 04:05 PM
janchuck's Avatar
janchuck
Hi-
Here are all the codes currently showing on the DIC:
TCS C 1277 H
C 1281 H
C 1283 H
C 1286 H
C 1287 H
A 0 LDCM
B 2252 H
B 2282 H
B 2284 H
U 1064 H
A 1 RDCM
2283 H
2285 H
U1064 H
A 6 B 0851
99 HVAC B 0333I don't see any codes that seem to relate to the speedometer problem. Odd!
Several codes relate to battery, which I just replaced. All codes have the H for history. I have not reset any of them.
The problems with the TCS Traction Control have been there for quite awhile. The speedometer problem is fairly new, but where are the codes??
Old Jan 6, 2016 | 11:17 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by janchuck
Hi-
TCS C 1277 H
C 1281 H
C 1283 H
C 1286 H
C 1287 H
A 0 LDCM
B 2252 H
B 2282 H
B 2284 H
U 1064 H
A 1 RDCM
2283 H
2285 H
U1064 H
A 6 B 0851
RESET ALL THOSE and see what comes back. When you have a GLUT of DTCs its difficult to see what's going on.
Start at the differential and check the speed sensor on the top passengers side of the differential housing. Make sure that the connector is plugged in and not damaged.
The Speedometer Speed signal malfunction DTC/s would be B-0516, P-0500, 0502, 0503.
You can disconnect the Sensor connector, drive the car and see if you detect the disconnected sensor..
Bill
Old Jan 6, 2016 | 11:23 AM
janchuck's Avatar
janchuck
Thank you! I will try that.
Old Jan 6, 2016 | 11:53 AM
dadaroo's Avatar
dadaroo
Bills approach is good as always.
I worked on an identical issue with a guy in England about 2 years ago. It ended up being the PCM. No codes and no speedometer function.
I'll look at what we did in that to refresh myself.
Mr. Sam
To Problem with speedometer C5 2000
