Water Proofing your BCM
Water proofing the circuit board is called CONFORMAL COATING. It is widely used in wet damp environments. GM Delphi didn't find it necessary.
I DO NOT know if it can be successfully applied to our BCM. There are PLENTY of smarter people on here that can chime in on that topic. Your best bet is to SOLVE the water intrusion issues.
IF,,,,,,,,,,,,,,,,, your drivers side foot well is wet,, CHECK YOUR Cowl UDDER DRAINS!!!!!!!! Do your wipers work properly??
Other places where water can get in are:
Door hinges
Rubber door seals
Window seals
Window Adjustment issues
Targa top seals front
Targa Top seals rear
A Pillar to window seal issue
Cowl well to body seal..
Strip out the drivers side seats & carpet and systematically wet down the car in sections starting LOW and see where the water gets in. You will need a helper to watch for leaks inside while you wet it down.
You "should" remove the drivers side carpets and get them properly clean and dry. While they are out, wet down the car and see where the water is coming in. FIX that issue!
Ive been down this road and felt the pain. TRUST ME,, it can get expensive the longer it exists.
BC
Door hinges
Rubber door seals
Window seals
BC
