Help diagnose clutch issue
Mine was a bubble in the Hydraulic T.O. Bearing.
Drove me nuts until I found that the Rubber Boot in the master Cylinder was plugged and fluid was not draining into the reservoir.
Look for the C5 clutch vac bleed post, worked
I'll tell you this, the weirdest clutch issue ever.
It's worth a try.
Look for the post that is about Clutch Bleeding. You use a large rubber sink stopper and connect it to your Vac hand pump. Then suck out all the fluid you can, I used a new Turkey Baster. refill and pull a vac on the clutch master cylinder. I also had a friend slowly, I do mean slowly depress and release the clutch pedal. his worked out the bubble.
I bought my C5 Vert cheap because the P.O. though he had a bad clutch and ruined the trans.
I've dealt with so many different clutch issuers over the years, but this one was a complete surprise.
I've never seem a OEM leaky T.O. Bearing, at least one that had not had the hydraulic line disconnected. Contamination is the worst enemy for hydraulics. But, it is still worth trying this Vac pull a few times,,, Better than tearing your Clutch out. Slow leaks do occur but very minimal, and can be refilled over several years, I've got one of those too.
Also, if you have a non OEM Clutch, call the maker or where you purchased it. As Improper clutch release, my experience, was always the pressure plate. Is this something new ??
If all this fails, replace the master cylinder with the factory hydraulic line attached. I would recommend that you install a factory OEM master. Then re-bleed. Be Darn positive your lines are clean prior to removal. Use soap and water. DO NOT use cleaning solvents.
Let me know if you need anything else. PM, and I'll send you my phone number, photos if needed
Good Luck !!
Michael
It's worth a try.
Good Luck !!
Michael
Good Luck and be safe !!
Michael
Bill
