c5 hesitating
Old Jan 11, 2016 | 10:10 PM
az bowling green's Avatar
az bowling green
3rd Gear
Default c5 hesitating
I have a 2000 corvette that has a bad "stumble at 2500 rmp then it picks up then stumbles again around 3500, then at about 4000 it feels like reduced power almost like a rev limiter.
I have changed the fuel filter and just did the ls1 to ls6 pcv mod, thinking it was a vacuum leak in the pvc system neither of these helped. any thoughts?
Old Jan 12, 2016 | 04:00 PM
az bowling green
3rd Gear
I pulled the codes today. These are what I got.
B1001h. B0521h. U1096h. U1064h. U1016h.
Just bought new plugs and wires. Will post if they help.
Old Jan 12, 2016 | 04:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The B Codes are associated with Body Control Module (BCM ) errors
The U series tells me that you had some serial data buss COMMUNICATIONS issues.
There are most likely some other problems that your not seeing. Do you see any crazy messages or gage readings on the IPC???
CLEAR ALL THE DTCs
When you experience the issue, without turning off the ignition, clear any messages in the DIC by pressing reset and then go right into reading the DTCs. Post what you see there.
Bill
Old Jan 12, 2016 | 06:49 PM
az bowling green
3rd Gear
Thanks Bill
I changed out the spark plugs and wires and reset all the codes. Took her for a ride it is definitely running better not doing it every time now but it did happen three times in a 5 mile drive. There were no code anywhere when I got done with the ride
Old Jan 12, 2016 | 10:02 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If it were MY car, here is what I would do:
Get a Fuel Pressure Gage that you can monitor with the hood shut. Monitor the fuel pressure during the stumble events.
What is the battery voltage reading at the time of stumble?
Are there any messages on the DIC when the car falls on its face?
Bill
To c5 hesitating
