Oem stereo aux adaptor
Old Jan 19, 2016 | 08:20 PM
Pat Tucceri's Avatar
Pat Tucceri
Default Oem stereo aux adaptor
Has anyone used the " mp3 me" adapter? How is it, crystal clear quality?.. I know you need to put it onto a radio station.... if that station doesn't come in clear -static will it work just as good? Cheap alternative to having to install a entire new head unit, trim kit, wiring, etc.
http://www.corvettemods.com/C5-Corve...dCPHwodNgsDvg#
Old Jan 20, 2016 | 12:11 AM
glfrmrk's Avatar
glfrmrk
Yes, I have used one in my 1993 Z28 with an Alpine head unit. It is a compromise with regard to clarity. I went with a PXDP and a PXHGM4 in my '03 Z06 and it is as clear as anything. Call Dennis at Double D mods.
Old Jan 20, 2016 | 05:48 AM
73Corvette's Avatar
73Corvette
I also upgraded to the Kicker speakers...
Sound deadening REALLY helped...
and DO THIS...
https://www.corvetteforum.com/forums...ell-liner.html
Old Jan 20, 2016 | 01:33 PM
pmr2000's Avatar
pmr2000
What's the difference between this and a $10 FM transmitter?
Old Jan 20, 2016 | 04:40 PM
Forcedvert's Avatar
Forcedvert
That adapter goes in through the cd changer input so it sounds as good as a cd, he also has a Bluetooth adapter so he doesn't have to connect directly to phone or iPod! I have one without the Bluetooth and it sounds great.
Only negative I've noticed is the shuffle only seems to go to the same several dozen songs or so even though I have hundreds on my phone? Not sure what causes that, maybe someone who knows will chime in on that.
Old Jan 21, 2016 | 11:08 AM
pmr2000's Avatar
pmr2000
Ah thought it was FM looking at the package- is this any easier to install than others that use the cd aux? Or do you need to remove the stock head unit?
Old Jan 21, 2016 | 11:37 AM
95wht6spd's Avatar
95wht6spd
I have that issue in another car, where I use an MP3 player and connect from headphone jack to USB of head unit. It will only shuffle A-F for some reason.
Old Jan 21, 2016 | 12:17 PM
pmr2000's Avatar
pmr2000
Shuffle problem sometimes the firmware on the player...if you look at the total # of songs on your player should match the song 1/ of 1000 total during shuffle.
I have a lossless player that had a 5000 song limit on shuffle.
Old Jan 21, 2016 | 10:02 PM
Forcedvert's Avatar
Forcedvert
I was talking about the one 73corvette pictured. I'm not familiar with the one in the op, sorry for the confusion.
Old Jan 21, 2016 | 10:11 PM
Forcedvert's Avatar
Forcedvert
What are you referring to as the player? I use my iphone as the player going through a isimple adapter attached to the car stereo's multidisc cd changer input, I figured the problem was the isimple adapter! I've been meaning to look into it but have not yet!
Anyone else have one of thes isimple adapters and figured this out?
To Oem stereo aux adaptor
