Help with Vacuum Lines?
Old Jan 20, 2016 | 11:35 AM
chad911sc's Avatar
chad911sc
Default Help with Vacuum Lines?
I have a few pics of unidentified parts and lines that I need help with. I have a 1998 C5 that I have done the head and cam swap and now putting the thing back together and do not know what these part do or what hooks up to them. PIC 1
comes off of the intake manifold and goes to this piece which in turn connects to the piece in pic number 2 which is powered.
PIC 2 is the piece that i'm not sure what it is or where the two ports connect too. One is a rubber elbow that looks identical to the vacuum line size that is used on the back of the intake for the A/C controls. Port #2 is on the right side of this thing and not sure if anything goes to it or not. You can see it better in pic #3.
And lastly what does this nipple coming off of the fuel rail connect too in Pic #4
Thanks for the help in advance, this is the last steps of a 4 month process of doing a complete overhaul on my C5.
Thanks, Chad.
Old Jan 20, 2016 | 01:08 PM
enoniam's Avatar
enoniam
In pic 4 that is the fuel pressure regulator and it should have a vacuum line to that nipple from the intake manifold.
Old Jan 20, 2016 | 01:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The rubber 90 deg elbow fitting on that regulator is suppose to be vented to atmosphere just like it is in the picture. In 98 the fuel press regulator referenced off of a fitting attached to the air bridge. There is a up-grade kit to T it in to a fitting of the vacuum port on the intake. The kit gives it a better reference signal.
Old Jan 20, 2016 | 02:46 PM
LoneStarFRC's Avatar
LoneStarFRC
Several of the items you are dealing with are specific to the '97 and '98 cars ONLY. The items you are asking about relate both to the emission control system and fuel pressure regulator mounted on the fuel rail. AGAIN, a number of these items are '97/'98 specific.
Here's a couple pics of the OE setup.
Picture 1
Picture 3
NOTE: Item #19 in the first picture is the SAME piece as item #578 in the second picture and item #7 in the third picture. It is the fuel pressure vacuum reference line Bill spoke of and normally attaches to a hole in the left side of the OE air bridge (see picture #3).
HTH
Old Jan 24, 2016 | 10:58 AM
LoneStarFRC
Originally Posted by chad911sc
.........Thanks for the help in advance, this is the last steps of a 4 month process of doing a complete overhaul on my C5.
Thanks, Chad.
You're welcome....
Old May 26, 2025 | 10:40 PM
Darik7's Avatar
Darik7
2nd Gear
Picture 1
Picture 3
HTH
in picture 2 #563 what is this, what is the part number
Old May 27, 2025 | 09:56 AM
lucky131969's Avatar
lucky131969
evap purge vacuum switch
To Help with Vacuum Lines?
