Bent pushrods... or more?
Old Jan 30, 2016 | 11:38 AM
vetteme97's Avatar
vetteme97
Default Bent pushrods... or more?
Did some high speed driving the other night with some friends, might have missed a shift, I don't really remember. Anyways, now I have the loud tapping raising with rpm synonymous with a bent push rod(s). That seems easy enough to fix, however when I drove home the car would die every time I pushed the clutch in. When I started it the computer would keep it running however every stop sign and stoplight would kill it. Could I have a bent valve? Or is this possible with just trashed pushrods?
Old Jan 30, 2016 | 01:13 PM
Closer_2001's Avatar
Closer_2001
Back in the day on my 01 C5, we were doing some high speed runs on an old air strip.
The car was bone stock.
Grabbed what I thought was 3-4 at about 105, except pulled 3-2 accidentally. Let out the clutch and clearly over-revved the car. (B&M Ripper was installed immediately thereafter - to this day, still felt like the stock shifter went 3-4).
The Check engine light was flashing and random misfires.
- bent multiple valves
- push rods surprisingly not bent
- rockers looked fine
Upon reassembly, the valves would float on the Dyno (had before and after), so ended up upgrading to LS6 spec springs. Problem solved.
Hope that helps
It's pretty easy to pop the valve covers, remove the rockers and pull the push rods.
Old Jan 30, 2016 | 01:16 PM
zachaeous's Avatar
zachaeous
I would pull the valve covers and physically look at the push rods. I would also remove the oil filter and cut it open and check for any metal that may be in the filter. I would not run the engine anymore until I checked what I could without starting it.
If you find metal in the oil filter post up some pics and let others help you with the problem.
Good luck
Old Jan 30, 2016 | 01:25 PM
tommypenguin's Avatar
tommypenguin
It would help if you also pull and post any Codes that may be set in your DIC. If you do not know how here is a link to a youtube video:
https://www.youtube.com/watch?v=SviRjIsy9G4
Good luck
I second this.
Old Jan 30, 2016 | 02:23 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by tommypenguin
I second this.
Typically on a stock engine the pushrod is your "fuse" so to speak and will bend first but the thing is...what caused it to bend. Generally to bend it something has to hit it...like a piston to valve. Might have just touched it, but better safe than sorry. Easy enough to pull the valve covers and rockers and check them.
checking the oil filter is never a bad idea...I would even do a plug check. If you think something worse happened do a compression/leak down.
Old Jan 30, 2016 | 02:37 PM
RonSSNova's Avatar
RonSSNova
Compression test will tell if you bent a valve.
If it will idle, use a stethoscope (or long screw driver etc) touching the valve covers around the areas you hear the noise from.
Then pull the cover and have a look.
The issue might be obvious
Ron
Old Jan 30, 2016 | 04:18 PM
vetteme97's Avatar
vetteme97
Well, I just pulled the pushrods. It seems as if they are all slightly bent if the "roll it across the table" test is legitimate. I hope swapping those out will fix the problem. Would that explain the car dying when the clutch was pushed in? That part still doesn't make much sense to me
Old Jan 30, 2016 | 05:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Even if you find bent pushrods,, you SHOULD check for damaged valves.
Rent, borrow, purchase a compression tester and check each cylinder for proper and equal compression
If you have a slight valve seat leak, fixing it now is easy by replacing the valve. If you wit and burn a valve, you could damage the seat and that will be more money.
Bill
Old Jan 30, 2016 | 05:09 PM
vetteme97's Avatar
vetteme97
Andddd I'm finding metal shavings in the oil sitting in the top of the head... any ideas?
Old Jan 30, 2016 | 06:36 PM
Robert Perkins's Avatar
Robert Perkins
At the least the heads need to come off and lifters, push rods and valves checked. Check top of pistons for hit marks from valves. Pull and cut open oil filter. If it is full of metal pull and rebuild engine.
Old Jan 30, 2016 | 10:30 PM
tommypenguin
I would pull the heads and all the components in them, if you see damage on the lifters the cam is going to need to come out and be inspected. How was your oil pressure?
Old Jan 31, 2016 | 01:42 PM
ZZ06's Avatar
ZZ06
uh-oh....sounds like you may have hurt the motor. I'm sure it isn't what you want to hear but water under the bridge now. Like others have said, now that you,ve seen metal shavings, it would be best if you pulled the heads and inspect/R2 what is damaged. Hell, if funds allow, send em off for a port job. Good luck!
Old Jan 31, 2016 | 02:39 PM
vetteme97's Avatar
vetteme97
Yeah! Thats the plan, i have a feeling I bent some valves. I'm checking the oil filter today. The shavings weren't big, very tiny slivers. Hoping they came off the threads from the rocker arm bolts when I removed them. The heads will be sent off to a local machine shop for porting, polishing, and a valve job. I already have a small Comp 216/220 cam and ls6 springs coming in tomorrow Hopefully that fixes the problem. And idk about oil pressure. Tbh my sending unit went out. At least I have an opportunity to fix that and make my baby a bit faster
Btw, thank y'all for the great advice! This forum always comes in clutch when I need the help. Y'all are the best!
Old Jan 31, 2016 | 03:04 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
How does the "action" of the rocker arms seem? Is it smooth? There have been problems reported with the OE trunnions of the rockers "going south", and either damaging, or out right spitting out the needle bearings. Both CompCams and Summit Racing have a kit that replaces the trunnions and bearings with a much better set-up. There's also a kit out there, that replaces the needle bearings with a hardened "bushing"....I just don't remember, off the top of my head, the sponsor's name, but they posted a thread about their products within the last week or so...
Old Jan 31, 2016 | 03:33 PM
vetteme97's Avatar
vetteme97
Yes, I moved each of them by hand yesterday and its like butter. Smooth as can be
Old Feb 3, 2016 | 05:00 PM
vetteme97's Avatar
vetteme97
Well guys, I took the heads off of the motor and absolutely nothing is wrong. No sign of the valve tapping the piston even once. My sketchy table is probably more bent than the pushrods rolled on it. Anyways, a mechanic buddy of mine looked everything over and told me it was most likely rod knock So I'm pulling the motor and rebuilding it
Old Feb 3, 2016 | 05:02 PM
Robert Perkins
Keep us updated on what you find.
To Bent pushrods... or more?
Old Feb 3, 2016 | 08:25 PM
Paul 75 L82's Avatar
Paul 75 L82
Do what Bill said, that's good advice. Report back, you have the best here to help you out.
Old Mar 3, 2016 | 12:56 AM
vetteme97's Avatar
vetteme97
Well I know it's been awhile. Long story short I couldn't find anything wrong so I pulled the motor out of the car. I am in the middle of tearing it apart right now. I was planning on replacing the lifters even though they appeared fine. I checked them over one more time tonight rolling them on my arm, checking for scuffs on the rollers. I thought to push down on the pushrod cups on the top to see if any of them seemed spongy. On the second lifter I checked the pushrod seat pushed into the lifter with little to no effort, I'm talking a one finger push. And now its stuck down in there. Could this be the issue I heard? There isn't any damage on the cam or the roller.
Old Mar 3, 2016 | 01:16 AM
zachaeous's Avatar
zachaeous
Thanks for reporting back. I definitely think that that would cause a tapping noise.
