need o2 sensor help
Old Feb 6, 2016 | 07:47 PM
justbrad's Avatar
justbrad
Default need o2 sensor help
i have 02 with long tube headers my front 02 sensor stopped working or only worls when it wants to i assume its connected to my air fuel meter cause sometimes it works sometimes not.napa tells me I need a 02 sensor for headers is this true?if so where do I find one or is parts guy wrong
Old Feb 6, 2016 | 09:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Having a tough time understanding your issue.. IF,, you have a AFR Gage in your car,, you have a WIDE BAND O2 sensor installed.
The standard C5 O2 sensor will NOT support a wide band gage.
SO, Is your wide band meter intermittent? Or,,,,, are you getting DTCs for the OEM style O2 sensor issue??
BC
Old Feb 6, 2016 | 10:03 PM
grantv's Avatar
grantv
Not entirely sure what you're saying either, but if you have headers with one bung per side, the factory O2 sensors should be good.
Edit; how do you know it doesn't work, codes?
Old Feb 6, 2016 | 10:18 PM
Forcedvert's Avatar
Forcedvert
My afr was intermittent and just today I had it up on a lift and found my mechanic ran the wire from it behind the tunnel heat shield and it was melted to the shield so I had to reinsulate it and wrap it in some heat resistant tape. You may have a similar issue. This is a wideband sensor located where one of my back o2 sensors were.
Old Feb 7, 2016 | 12:32 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
LT headers open up a whole new can of worms---That's why they are illegal in most states
Reason being is that with LT's the front 02 bungs can be moved further aft as much as 3 ft---This re-location causes the 02's to not read correctly at P/T and not heat up properly--There is NO 100% fix for this issue---However you can make it much better by installing rear 02's onto the front locations (as the rear 02's are far more sensitive)
2ndly a tuner can LOWER the 02 switching points somewhat to compensate for the further back locations------making them oscillate at a much lower millivolts level---(the lower the millivolts average the LEANER the P/T AFR )
To need o2 sensor help
