Axle Vibration Damper Problem?
Old Sep 1, 2002 | 10:19 AM
KGoodwin's Avatar
KGoodwin
Default Axle Vibration Damper Problem?
I've noticed some oil leakage around the transaxle only on the driver's side (left) which seems to be coming from the axle vibration damper. Does this damper contain oil? Does it leak? Or is my rear axle/transmission the source of the oil?
Old Sep 1, 2002 | 12:10 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Default Re: Axle Vibration Damper Problem? (KGoodwin)
There is a fairly common problem with the seal on the drivers side of the differential. It's the one where the axle goes into the housing. These leak and need to be replaced. A small amount of gear lube coming out at this location can get slung all over the bottom of the car making it difficult to find leak location. Search other threads, there is detailed info available.
