Oil pressure sending sensor replacement?
Old May 11, 2016 | 05:43 PM
  #41
DNFC5's Avatar
DNFC5
Originally Posted by akapounder
just on the pipe fitting (the one going into the block) if the fitting has a tapered flare you do not need (or want) tape on them !!!
Thanks aka pounder!
I'm going to replace the intake gaskets while I'm at it. She's an '02 with 78k on the clock. Anyone recommend a gasket over the stock OEM parts from the dealer?
Old May 11, 2016 | 05:45 PM
  #42
Pounder's Avatar
Pounder
1/4 mile/AutoX
the flare fitting no the straight fitting yes (tape)
Old May 11, 2016 | 05:46 PM
  #43
Pounder's Avatar
Pounder
1/4 mile/AutoX
I used Fel Pro from Summit !!
Old May 11, 2016 | 05:49 PM
  #44
DNFC5's Avatar
DNFC5
i used fel pro from summit !!
Old May 11, 2016 | 05:52 PM
  #45
DNFC5's Avatar
DNFC5
Where did you get the 90 degree fitting you just posted? Will that let me skip the double adapter pictured in other posts shown in this thread? Is it -an4 to 16 mm?
Old May 11, 2016 | 06:04 PM
  #46
Smoken1's Avatar
Smoken1
If your going to use Teflon tape use the yellow style..It is made for this kind of use
Old May 11, 2016 | 06:17 PM
  #47
Pounder's Avatar
Pounder
1/4 mile/AutoX
yes it is on my doc's that I posted, the less fittings the better for me anyway !!!
Eaton Aeroquip 2025-6-4S 90 Degree Female Elbow, JIC 37 Degree & NPT End Types, Carbon Steel, 1/4 JIC(f) x 3/8 NPT(f) End Size, 1/4" Tube OD, 3/8" Female Pipe Size: Flared Tube Fittings: Amazon.com: Industrial & Scientific Eaton Aeroquip 2025-6-4S 90 Degree Female Elbow, JIC 37 Degree & NPT End Types, Carbon Steel, 1/4 JIC(f) x 3/8 NPT(f) End Size, 1/4" Tube OD, 3/8" Female Pipe Size: Flared Tube Fittings: Amazon.com: Industrial & Scientific
Old May 11, 2016 | 09:44 PM
  #48
Stroker87's Avatar
Stroker87
most local auto part stores have the felpro gaskets in stock
Old May 11, 2016 | 09:48 PM
  #49
DNFC5's Avatar
DNFC5
Thanks, and just so I'm clear, the 3/8" pipe thread is equivalent to the 16mm x 1.5 threaded base of the sensor? I realize pipe thread is different from standard threaded hardware, just making sure before I buy hardware that the link to the adapter is for the correct size.
