I'm big on maintenance, as change the brake fluid on the cars in the family fleet on a regular basis. However, since most of the cars now have plastic m/c reservoirs, I've been struggling.
I have an ancient Plews "bleeder ball" that was the nutz, for the metal m/c's, but won't work with the plastic ones. So, I bought one of the Phoenix suction tools, and while it works OK, it gets tiring squeezing the thing like a hand gun, 15-20 times at each wheel.
I was looking at the Motive bleeder, but saw a lot of mixed reviews, at least on the Summit Racing page. Anybody have any comments?
I bought one at Harbor Freight... used shop air and would suck it through the bleeder fittings... Cheap maybe $20-$25 worked great!!
Sorry don't have the part number or name
Pete
I have the Motive Power Bleeder and used it for mine. I was a bit nervous as this would be the first time using a pressure bleeder like this, but it was much simpler than I had anticipated. I also used a Youtube video as guidance. Here it is:
+3 For the Motive. They have adapter lids for GM, Miata, Ford, etc.
Simple and easy to use. Don't put any fluid in the Motive, just use it for reservoir pressure.
Another vote for the Motive Power. I've used it on my Vette and it took me around 15 minutes to bleed the entire system. Worked great. I also used it to bleed my pickup after I replaced some rusty brake lines.
Let me make sure I understand what you're saying......You're using the Motive tool to pressurize the M/C, so it pushes the fluid out, that's in the reservoir, and refilling the reservoir pretty much after you flush each caliper?
That's pretty much it. First I drain the MC and fill it with new fluid and since I've got 01 & 04 vettes they do the RR LF LR RF bleed pattern and I can get one rear and one front caliper before I have to refill the reservoir.
I use a one way valve connected to a piece of hose. No speed bleeders required. Takes 15 min to bleed the whole system start to finish with the wheels off. Cost $5-10. My brakes are rock hard.
I don't see the point of buying the motive. This is easier since you can leave the reservoir open to put in new fluid.
I never though of using the Motive tool just as a pressurization tool. The old "bleeder ball" I had, worked well, but using the quick disconnect fitting, when done flushing the system, was tricky. Sometimes I'd get a little fluid spillage......not good.
Another vote for the Motive. I'm a backyard mechanic not a pro and read that if you get an air bubble in the ABS system its a trip to the dealer so they can use a Tech II to fix it. (Can someone confirm that?)
That was enough for me to buy one. Fast, easy, little to no mess I recommend it. I have nice clean fluid and a solid brake pedal.
The bleed (pressure bleed) order is in the forms here somewhere which is what I used.
For you backyard mechanics, if you have a bubble in the ABS just put the rear wheels on jackstands and put in in first and "drive". You will confuse the abs and set it off. This will cycle the bubbles out.
If that doesn't work go slam on the breaks and trigger the system.
Nice vid from Froggy. but wondering why he doesn't load the motive bottle with fluid once he fills the brake reservoir? It's made for this very purpose and that way you don't have to refill the reservoir between calipers.
I used the Motive along with the Tech 2 and did the ECBM complete auto bleed !!!!!!!!!!!! I now know every component is working as it should !!! and my entire brake system has fresh fluid !!!
