M6 owners
Old Mar 15, 2016 | 08:12 PM
phil hunter's Avatar
phil hunter
4th to 6th? I never use 6th gear unless I'm on the Interstate. Can't image using it at 45 mph.
Phil
Old Mar 15, 2016 | 08:13 PM
SoAlVette's Avatar
SoAlVette
I have the electronic cags skip from compliance parts. Easy install in the engine fuse box
Old Mar 15, 2016 | 09:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LMFAO! When my Z was STOCK, I could shift into 6th at 25- 30 MPH and the engine would NOT complain one bit. It didn't have any TORQUE but, you could use that gear.
Old Mar 15, 2016 | 11:21 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
to be fair the z has lower 6th gear !!!!!!!!!
Old Mar 15, 2016 | 11:24 PM
StingrayRebel's Avatar
StingrayRebel
a zr1 6th gear is even better
Old Mar 16, 2016 | 12:12 AM
When I had my '99 and '00, both six speeds, I definitely installed the CAGS bypass on the cars.
Old Mar 16, 2016 | 04:35 AM
strand rider's Avatar
strand rider
I considered buying the extra part , from reading here, back when I first bought the car.
However my car doesn't sound like it is in the right power band if I keep the revs down enough to activate the shift block. I know it is not designed as a high rev screamer, but I like to at least let the thing breath a little before the next shift.
Old Mar 16, 2016 | 03:08 PM
Studying4boards's Avatar
Studying4boards
Just shift from 2-4-6.
Old Mar 16, 2016 | 03:18 PM
John Nowak PE's Avatar
John Nowak PE
Disconnected ours almost right away. I had the CAGS bypass kit in hand before the car showed up. For me, it was a matter of principle - I ordered a MANUAL transmission, meaning I get to choose what gear and when.
I will often "skip shifts" when just cruising around: 1st to 3rd; 1st to 4th; 3rd to 5th; and even 1st or 2nd to 5th.
