2002 Corvette won't start/crank.
Old Mar 17, 2016 | 06:58 PM
FrostyC5's Avatar
FrostyC5
1st Gear
Default 2002 Corvette won't start/crank.
Hello Everyone,
Recently, car has been having some issues. Parked it and covered it with a cover about a week ago (was promised heavy rain). Come back 3 days later, both windows are down (even though I am 100% sure they were closed when I covered the car), passenger side carpet is soaking wet. I dry it with paper towels, cloths, and a hair dryer overnight. Come back next morning, jump start it, works just fine. Drove it for a couple days, parked it again. Come back yesterday, passenger side carpet is wet again, I follow the same procedure but this time disconnect and take out the BCM (was afraid it would get wet). This morning I reconnected the BCM, everything is dry, car won't start. Car won't crank. Key is in 3rd position, gauges don't move, no lights, can't even pull the codes with holding down option and pressing fuel/trip 4 times. CEL is on. When I turn the key from 3rd position to try and start, nothing. No cranking, no sounds, no clicking, just dead silence. Windows and power locks work, as do headlights and radio.
Any ideas? Tried hooking up the battery to my Forester, nothing. No changes. Could it be because the computer is unhappy I disconnected the BCM?
Thanks to everyone in advance!
Old Mar 18, 2016 | 07:10 AM
dadaroo's Avatar
dadaroo
I would open up the BCM and inspect it for moisture first.
Next we will need to check for voltages after the ignition switch.
Mr. Sam
Old Mar 18, 2016 | 07:40 AM
vettenuts's Avatar
vettenuts
Do you have a window valet? Not sure if that is why the windows opened.
I would also wipe down your key good to clean it off. Have a friend who's car was very finicky if he kept his key where it could get damp. Same symptoms. Simple and no cost test.
Old Mar 18, 2016 | 10:03 AM
v6turbo87's Avatar
v6turbo87
Your Battery is totally dead. Taking the BCM out and putting it back in won't confuse the computer. I bet if you measure the battery with a meter its is dead. Take it out and put it on a charger. Try another battery if you have one. Something is draining your battery. Driver's seat is often an issue so pull the circuit breakers in the passenger side kick panel fuse box along with the one for the passenger seat. Contrary to what I have often seen posted, you should not have to leave your car on a tender all the time. If the battery is going dead after a few days something is causing it. It happened to me and it was in fact the driver's seat.
Old Mar 18, 2016 | 10:28 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Dead Battery was my initial thoughts also. I would also check the battery cable torque to be sure it properly tightened!
Old Feb 23, 2019 | 07:04 PM
7th Vette's Avatar
7th Vette
I had a 1987 that would do this occasionally. The Problem Was in the chip reader or the chip in the key. My mechanic put a bypass around the chip. Never had the problem again. The bypass also bypassed the security system on the steering column.
Old Feb 24, 2019 | 10:02 AM
Grandpa1's Avatar
Grandpa1
Not to hijack this post or be argumentative, one sentence here I disagree with. You say contrary to whet you have seen posted here you should never leave your car hooked up to a tender all the time.
Why do you think that?
They are named "Battery Tender" or "Battery Maintainer" for a reason.
If used properly it will really extend the life of a battery. I have been using them for over 30 years so I guess I speak from some experience. I have used them on bulldozers, backhoes, motorcycles, boats, forklifts and cars since the 80's.
I had a tractor once that I didn't use for 14 months but I could see the lights working on the maintainer and when I tried to start the tractor up it spun up like it had a brand new battery in it.
If you put a maintainer on a fully charged battery it will keep it that way for a long time. The technology has improved so much.
I place mine to where I can see the lights on them. Right now the ones I use show a one solid and one blinking light it the battery is fully charged. If I see it with both lights solid on I know something is wrong and check it out.
They are not chargers unless it says it is a charger and maintainer.
I'm sure some have failed but I have never had one go bad. They just got stolen.
Good luck!
Old Mar 3, 2019 | 05:12 PM
ncali's Avatar
ncali
go to the zone and ask for a glass mat battery
Old Mar 3, 2019 | 06:03 PM
Robrote's Avatar
Robrote
This post is 3 years old. I'm sure he got it running by now.
To 2002 Corvette won't start/crank.
